LS1 oil pan gasket question
Old 11-01-2011, 01:53 AM
TruBloodTransAm's Avatar
Exclamation LS1 oil pan gasket question
I'm doing an LS1 oil pan swap soon. I think I've got everything I need, except for the gasket.
What's the cheapest place to get one? I got the part number for it, 10108676. I searched online most vendors have it for around $35+shipping. Seems kinda expensive.
This may sound stupid, but can the stock gasket be reused? The motor has 77k on it. The only reason I ask is because when I did my pacesetter LT headers, everyone said to just reuse the OEM metal GM gaskets. I figured maybe the oil pan gasket can be reused as well?
Thanks!
Old 11-01-2011, 11:45 AM
5.3LJimmy's Avatar
35 dollars is about as cheap as you will find. The gasket is reusable but I would change it if it was me. Since in most cases the motor needs to come out of the car to replace the gasket, it's cheap insurance.
Old 11-01-2011, 12:46 PM
slt200mph's Avatar
If it is not leaking do not change it. Mine is 11 years old with 244,000+ miles on it and still working fine. The factory gaskets are very very good on these LS series engines.
Old 11-01-2011, 03:08 PM
sdetweil's Avatar
but he said he was changing the oil pan.. I am about to do the same, camaro pan being swapped in for a truck pan to reduce the sump depth.
the used engine has 108k miles..
yes, $50 (where do u get them for $35) is 'cheap' insurance, but every $50 adds up.
spent $200 just to get the danged thing running.. $ 100 I wasted cause I didn't need plugs or the fuel pressure regulator, but didn't find the wiring problem til after they were changed.
Sam
Old 11-01-2011, 03:15 PM
5.3LJimmy's Avatar
http://www.texas-speed.com/p-215-gm-...an-gasket.aspx
Old 11-01-2011, 03:47 PM
GMPartsDirect and TSP have them for that price.
If I have to get it, I'll probably get it from ByunSpeed. They have free shipping on orders over $100. I need to order some suspension stuff anyways. Plus, no sales tax since they're out of state to me (unlike TSP).
Old 11-01-2011, 05:20 PM
kwiksilverz28's Avatar
Get a new one, but the motor most certainly does not need to come out to change. If I remember, about a 90 minute job. Drop the k member and use hoist to hold engine up.
But, again, spend the money and avoid a leak...
Quick Reply: LS1 oil pan gasket question
