Is the V2 and comp xer281 cam the same thing
Old Nov 1, 2011 | 11:15 AM
Bobby G's Avatar
Default Is the V2 and comp xer281 cam the same thing
Not sure if they are the same, I was going to order a cam from texas speed for $379, but summit sells the com cam for $399 and they sent me a coupon for $50 off $250? I was origanally going to go with a eps 226/234, or 228r, but this one sounds nasty.I am putting this in a lq4 motor , any ptv issues and what pushrods did you use. Also I have a ls6, and edelbrock headers, Yank ss3600 and 3.42 gears. Any dyno numbers with a that combo would be appreciated. Thanx
Old Nov 1, 2011 | 11:21 AM
thunderstruck507's Avatar
I would order the EPS cam and order some parts from summit (pushrods, springs, etc) and use the $50 coupon on those.
Let Geoff order a custom grind EPS cam for your combo and you will be very happy. I love mine, it has more low/mid range than my old cam and pulls like crazy up top.
Old Nov 1, 2011 | 11:24 AM
egott_91's Avatar
They have the same specs, but aren't the same cam.
Old Nov 1, 2011 | 11:25 AM
Bobby G's Avatar
Do you have any dyno numbers, and track times. What does you car weigh
Old Nov 1, 2011 | 11:29 AM
None yet, just got it back together.
Runs a hell of a lot harder than it did with the stock heads and 230/224 cam I had before. And not just up top, it picked up a lot of low end and mid range.
Old Nov 1, 2011 | 03:31 PM
red 95 t/a's Avatar
I had a futral f14 and spun a rod and junked the cam out so i went with the comp xer 281. No dyno but seems to run the same to me. V2,f14 and comp xer 281 are all the same specs. Im not saying there the same cams. I cant tell a differance in mine
Old Nov 1, 2011 | 03:33 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
They are CLOSE to the same specs
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Nov 1, 2011 | 04:38 PM
red 95 t/a's Avatar
I forgot you guys sold comp cams brand>Is that who you guys have grind your inhouse and custom cams?
Old Nov 1, 2011 | 05:24 PM
Comp grinds all of our camshafts to our specs
__________________
