Are these heads screwed up?
Old Nov 2, 2011 | 08:13 PM
Old_Yeller's Avatar
Default Are these heads screwed up?
I picked up an LQ9 from a guy who had already started "cleaning up" the heads. He took too much off in the bottom right corner of the intake runners and now there is a small ridge in the transition into the vertical wall of the intake runner. I will try to attach pictures. Would you guys use them? Don't really want to port them. He only touched the intake runners. Thanks.
Attached Thumbnails Are these heads screwed up?-head-pic.jpg   Are these heads screwed up?-head-pic-2.jpg
Old Nov 2, 2011 | 09:10 PM
A.R. Shale Targa's Avatar
Looks like the individual polished the runners...A MAJOR NO-NO !!!
If these heads are to be used I would re-sand them with a coarse (36 or 60)
grit cartridge roll on a die grinder. Exhaust ports and combustion chambers
are OK to polish just NOT the intakes.
Old Nov 2, 2011 | 10:31 PM
Old_Yeller's Avatar
I have the opportunity to pick up a set of 243 heads that have just been milled .010. I could pick those up but was worried about the CR being a little high. I know I could bleed some off with the right cam, but I don't want to have to turn a lot of rpms to make power. I also want to be able to run pump gas with absolutely no problems.
Old Nov 2, 2011 | 10:51 PM
Silver408z's Avatar
A lot of people run 11.5 to 1 compression on 93 octane. As long as you have 91 or 93 and a good tune you should fine with only .010 mill. Talk to a machine shop, use a compression calculator or talk to someone who knows mroe than me lol.
Old Nov 4, 2011 | 10:32 AM
Old_Yeller's Avatar
bump.
Old Nov 4, 2011 | 11:16 AM
parks450's Avatar
I wouldnt use them.....like stated above your not suppose to polish the intake runners, I would get the 243's their the best bang for the buck head and only being milled .010 youll be fine with compression.
Old Nov 6, 2011 | 11:28 PM
98silvermaro's Avatar
my heads were milled .30 and I had a 11.5 compression ratio and ran 93 pump gas with no issues
Old Nov 7, 2011 | 08:14 PM
Old_Yeller's Avatar
I appreciate the advice. I went ahead and got the 243 heads. Thanks
