Spun cam bearing?
http://www.youtube.com/watch?v=X8Nu-...el_video_title
Why didn`t I think of that.
You guys know if changing a cam bearing requires pulling the engine, or is there a way to do it with the block still in the bay, even if it means pulling everything off the front of the car? The car hasnt even been driven 20 miles since it first started making noise.
I just listened to You're video and I seriously doubt that is internal engine ,,,,,,,,,,,,but if it is ,,,,,,,probably in the valve-train such as a lifter . Sounds external to me .
Edit: Spinning a cam bearing is rare, usually a rod bearing will be first to go when there is a lubrication problem. The old 2.8/3.1 V6 iron motors used to spin cam bearings when the intake gaskets leaked coolant into the motor (they were priority fed to the cam, not the crank), but the V8's have never really had a problem unless they were installed incorrectly.
I think I have ruled that out though. I started it up this morning without the belt, and no unusual sound at all. I put the belt back on, and still no sound except the power steering pump whine, and after a minute or two the sound was there again, but very faint. Removed the belt again, and can`t get it to make the noise. Put the belt back on, and again, it`s there after a minute or two.
How difficult is it to replace the power steering pump?
Thanks again!
