problem with the engine
Old Nov 7, 2011 | 12:32 PM
q8.predator's Avatar
Default problem with the engine
Hey guys I have a problem with my S-10 ls1 swap
first of all when we finished the swap and hooked up all the wires and started the engine, pretty soon it stalled for no clear reason.
we disassembled the engine to see that the crankshaft is bent at the front and damaged the oil pump.
after we replaced the parts and assembled the engine, we started the engine which cranked for about 10 seconds.
when we tried to get it started again it would barely start and when we checked the spark plugs, we found that they are covered in carbon.
we replaced them but still the engine wouldnt fire.
Old Nov 7, 2011 | 12:39 PM
King Nothing's Avatar
Cam? Heads? Headers? Stock tune??
Old Nov 7, 2011 | 01:37 PM
RARON455's Avatar
Computer throwin any codes,,,how about the reluctor wheel runout, did you check it, can cause a problem exactly like you describe.
Old Nov 7, 2011 | 03:39 PM
joecar's Avatar
How did the crankshaft get bent...?
How do you know the rest of the crank (and the reluctor) are not damaged or out-of-spec...?
Old Nov 9, 2011 | 06:04 PM
yes it has cam , stock heads #241, 2in headers stock tune coz it still in the progress
Old Nov 9, 2011 | 06:09 PM
no codes on the computer and the reluctor wheel runout i've been told about that also and others told me about the camshaft position sensor i don't know
Old Nov 9, 2011 | 06:13 PM
the crank shaft get bent coz the car that we take the engine from had an accident
so when we fig that we change it with another one
Old Nov 9, 2011 | 09:54 PM
What size cam and that might be why depending on size. I swapped my 853 heads for fresh 241's and a 227/224 cam. I had to feather the gas pedal for the first 5 or so minutes to keep it alive and it was on a the stock tune
Old Nov 10, 2011 | 03:31 AM
the cam is comp 581/592 lube 114
the problem now it doesn't start any more
check my other post to see a pics of the truck and the engine
