Stressed to the max...need major help figuring this out
Thanks pooter, that was helpful info. Might try the starter trick tonight to see if I really do need to pull my tranny again. As far as the water pump problem goes... my guage never went up but I pulled over as soon as I felt the rough idle and checked the usual 'vital signs'... felt the coolant cap and it wasn't warm so I got worried and cracked it open and it didn't let off pressure like usual. So I took the cap off and couldn't see coolant, ran into the gas station and bought the only coolant they had and it took about a third of the jug to top it off. Your thoughts? Also after I shut the motor off, a few seconds went by and the radiator started steaming?? It didn't do that very long and my motor didn't smell like it was extremely hot or anything, I could still put my hands on the intake and a few other places without it smoldering, lol.
The steam... well it's hard to say without seeing it.
Buddy of mine had his clutch pressure plate bolts back out and it didn't make noise but it vibrated the car bad if you revved the engine in nuetral. The bolts wore the holes oblong so the clutch plate was no longer centered and all that weight being off center causes a bad vibration.
Use loctite on the clutch plate bolts and flywheel bolts. Also it wouldn't be a bad idea to use ARP hardware, not necessary if you don't have time or $ to get the ARP stuff though, just extra peace of mind.
No problem.
Funny story about the avatar, ex gf of mine (built just like that, skinny with big fake *****) saw that picture in my picture album and got all jealous and mad and said "why don't you take a picture of me like that instead of looking at some other girl!!!??" I laughed and said "because I only have one gun" lmao she was not happy with that response.
Haha! Anyways after going through some other old 'symptoms' threads... I may try a new PCV valve just to see if that does anything. Looks like symptoms of bad valve could include hesitation, drop in MPG, oil consumption? If I'm cruising around 1500 rpm it will occasionally buck a little bit then smooth out. It's really weird and kinda scary at first. Idk, my car has done so much weird crap this week and it's hard to diag any of it because I know the diff is about to go, then I had the coolant issue--found the water pump to be the culprit, and then the PCV hose and idle issues... AGH!
Good luck to ya, and I hope ya get it figured out soon......sucks to be confined to an Altima
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
I do work at a dealership... but as the Parts Manager, so not enough down time to spend under my car on a lift. I can always use equipment and lifts on saturdays though. I'm about to pull it inside and hook it up to our scanner though and do a little data logging to check my fuel/misfire histories. I'll post up my results... Thanks guys for the input and keep it coming!
Ok, started trying to find dead cylinders... which the PCV issue fixed the low rough idle. BUT I can pull the number one wire off the plug and the idle doesn't change. I'm getting plenty of fire through the coil because it arcs to the valve cover. Pulled the plugs out of bank 1 and they all look great. So confused...
UPDATE* Complete noob tard moment... swapped the plugs and wires from the first two cylinders on B1... well when I took the second one out I had to break it loose like normal... number 1 not so much so I torqued em all in really good, clicked on the wires... yeah number one plug was a little loose. UGH
I haven't seen what happens when a flywheel bolt is loose but I have seen what happens when one gets sheared off and goes through a fuel line. Booom, car goes up in flames until it runs out of fuel or gets put out with a fire extinguisher or some other means.
#32
Still was having issues, NOT the flywheel thank goodness. That was just the culmination of paranoia with all of the issues I had and noises/vibrations that were due to other things found out today... checked all 8 plugs and all 4 in bank 2 were completely caked with black soot. BINGO had a dead o2 sensor. The codes were actually telling me something instead of the usual LT header codes thrown for no (important) reason, imagine that. ha oh and also beware of buying "denso" sensors for under 50 dollars online unless it's a trusted source because I was ripped! Had to order a brand new sensor from napa at work, same part number I was under the impression I had and they were in fact different. The new one was actually engraved with the Denso name... online purchased sensor only says 'made in indonesia' with a 5 digit number. GO FIGURE. But car's running great with new plugs also. Datalog readouts looked good also, actually going to closed loop for the first time in I don't know how long... OK end of rant but I'm so relieved even thought I'm out another 70ish bucks
