Waste Of Time-Cam W/O Heads
Old 11-13-2011, 01:22 PM
38DD2436's Avatar
Originally Posted by Paul57
If this is truly your goal then you should build for torque if you are referring to stop light (street) performance and don't have plans for a lot of track time.
What is your stall??
Its a T56. No stall
Old 11-13-2011, 01:40 PM
Paul57's Avatar
OK...I had a little translation problem with "vert" then. Apparently it is convertible not converter. Anyway, Torque is your friend.
Old 11-13-2011, 01:43 PM
adamantium's Avatar
Some inspiration
https://ls1tech.com/forums/drag-raci...s-engines.html
Old 11-13-2011, 02:22 PM
99Bluz28's Avatar
If you go with some of the better/newer lobes currently available, you'll make more power with a smaller more streetable cam. A smaller cam with all thing being equal will also have less exhaust stink, since your driving a convertable.
A EPS, LS 222/226, (-2* overlap) would be a good option.
http://www.engpwrsys.com/index.php?a...od&productId=8
Another good option is a custom grind, 223(lsl)/226(lxl) 114lsa (-3.5* overlap) or with a 113lsa(-1.5* overlap).
http://www.texas-speed.com/p-161-com...-camshaft.aspx
Old 11-13-2011, 02:26 PM
redtan's Avatar
Will a cam upgrade benefit performance with out replacing the heads?
I don't think I've EVER seen a cam swap (from the OEM cam) where it didn't make more power.
