Any difference in the bearings for Harland and Comp trunion upgrade?
Hey guys,
I might have not searched right, but I couldn't find anything related to the actual bearings in the Harland Sharp trunion upgrade vs the Comp Cams trunion upgrade. Apparently HS utilizes a big washer on the ends, and Comp does not.
But is there any difference in the style of the actual bearing?
Thanks!!
Thanks!!
Im unsure on what exact brand bearing is being utilized in the Harland Sharp kit, but Im sure its probably very comparable to what is used in the Comp trunion kit. We stick to using the Comp trunion kit when upgrading the factory rockers, and have had great success with the kit.
