new cam help
Old Nov 14, 2011 | 11:30 AM
JohnnyBz28's Avatar
Default new cam help
So when I first put together my setup I picked a cam based on budget. it worked for the time being but I'm not that happy with it. I would really like to get another cam with the same basic specs but with a better power band. Reason for staying with the same basic specs is because my heads are milled. Any input would be appreciated.
Current setup:
LS6 Intake
Texas Speed PRC Stage 1 LS6 heads w/ PRC dual springs .650 lift milled to 61cc
Patriot 7.4 hardened push rods
Patriot Performance 225/229 .580/.590 114+4 LSA Cam
LS2 Timing Chain
Ported, Polished and bump stop modded stock throttle body
SLP Lid
ARH 1x7/8" LT's
ARH 3" ORY
TSP Rumbler Catback
Old Nov 14, 2011 | 02:32 PM
JohnnyBz28's Avatar
No one?
Old Nov 14, 2011 | 03:57 PM
99Bluz28's Avatar
Current setup:
LS6 Intake
LS2 Timing Chain
SLP Lid
ARH 1x7/8" LT's
ARH 3" ORY
TSP Rumbler Catback
Better in what way?
Lower, higher, wider, narrower....?
Old Nov 14, 2011 | 06:46 PM
JohnnyBz28's Avatar
This cam is only good until 6k rpm's. When I'm at the track the power dies around 6200rpm's. I would like to be able to at least rev to 6400 at the track but this cam isn't capable of this.
Old Nov 14, 2011 | 07:01 PM
Sales1@Texas-speed's Avatar
Feel free to give us a call in the morning. We would be happy to get you set up with something that will give you the results your looking for.
Old Nov 14, 2011 | 07:05 PM
JohnnyBz28's Avatar
Thanks Aaron. I would call but I feel like it would be wasting your time as I don't have the cash to spend as of yet (holidays etc). I'm trying to see what I will need to save for. I know I will need new push rods and possibly new valve springs. I was also thinking of changing out my lifters for LS7 lifters.
Old Nov 14, 2011 | 07:15 PM
HAZ-Matt's Avatar
Not an expert but I am wondering how bad it is dying after 6200RPM?
With a 225* @ .050" duration, 114LSA and 110ICL (+4) the IVC should be 42.5* ABDC and by the comments I have seen from the gurus you would think power peak would be pretty close to 6200RPM (maybe a tad earlier... depends on other things too of course).
Do you have a picture of the dyno? What's the status of your fuel system?
If I am missing something maybe someone can fill me in.
Old Nov 14, 2011 | 07:20 PM
JohnnyBz28's Avatar
I don't have any dyno sheets with the rpm's indicated unfortunately. I have to go back to get some.
I've read that Patriot Peformance cams have "lazy" lobes. I could have misread though.
I'm running 42lb injectors with everything else stock. I will be upgrading the pump soon since I know that is one downfall to my fuel system.
Old Nov 14, 2011 | 07:25 PM
JohnnyBz28 feel free to call anytime, we are happy to help whether you are buying a product or not!
Old Nov 14, 2011 | 07:43 PM
JohnnyBz28's Avatar
Sounds good, thanks again Aaron.
Old Nov 14, 2011 | 07:45 PM
No problem man!
R6cowboy's Avatar
JohnnyBz28, what do you think about looking into a custom cam?
Old Nov 14, 2011 | 07:51 PM
JohnnyBz28's Avatar
That was pretty much what I was looking for, I just don't know enough about cam specs to actually pick one out myself. lol
Old Nov 14, 2011 | 08:21 PM
HAZ-Matt's Avatar
Sure. I have no idea what lobes they use. From the specs you are providing they don't have crazy lift... I could understand that reducing absolute power potential I suppose.
But as a thought experiment, pretend you had a 224/228 with Comp XER lobes, which would make the lift .581/.588 also on a 114 +4. Not an unusual cam at all. That shouldn't hit a wall at 6200RPM... the few dynos of cams sort of like that (from a rapid search) all would easily pull to 6500RPM.
I suppose I just don't get why yours would hit a wall like that. I realize the .050 numbers don't tell the whole story, but there is an entire generation of cams that are similar to what you run that should pull past 6200RPM. It seems like it should be more or less right in the range you want already. That is unless something other than the cam is contributing, or it is advanced.
Just an amateur's take on it though.
edit: here is a graph of a car with your cam
https://ls1tech.com/forums/dynamomet...tang-dyno.html
here's another one
https://ls1tech.com/forums/dynamomet...99-z28-m6.html
Old Nov 14, 2011 | 09:08 PM
99Bluz28's Avatar
Any Idea what your A/F ratio is at 6200rpm?
Are the valve springs set to the proper seat height?
Old Nov 14, 2011 | 09:14 PM
JohnnyBz28's Avatar
[imghttp://home.comcast.net/~sentinel00/dynotunegraph.jpg[/img]
here's another one
[imghttp://img149.imageshack.us/img149/1058/dyno.jpg[/img]
I actually just found my last dyno sheet and it does have engine RPM's on it:
(412/390 run)
Uploaded with ImageShack.us
Originally Posted by 99Bluz28
Any Idea what your A/F is at 6200rpm?
Not sure on the A/F. I bought the heads assembled from TSP so I'm sure they were set properly.
Old Nov 14, 2011 | 09:25 PM
HAZ-Matt's Avatar
It's hard to know for sure, but extrapolating I would figure it would gently curve down towards 6500RPM so that you could effectively use a 6400-6500RPM shift point to maximize average power. The green and red lines both basically stop at "indicated" power peak, which was 6100RPM more or less. Hard to say though, especially if it never really got tuned or logged up there.
Reminds me of when my car was dynoed after the 243's and LS6 cam was put on and they cut off the dyno at 6000RPM... which shouldn't have been to peak power yet.
Do you have any data logs up there?
Old Nov 14, 2011 | 09:26 PM
99Bluz28's Avatar
How your fuel pressure, and how's it hold up in the upper rpm's?
I'm thinking your running out of pump once you get into the upper rpm range.
Old Nov 14, 2011 | 09:32 PM
HAZ-Matt's Avatar
That was a thought I had. Shouldn't be running out of injectors with 42pph's.
Old Nov 14, 2011 | 09:37 PM
JohnnyBz28's Avatar
No data logs unfortunately. That dyno run wasnt with my tuner. As far as fuel oressure goes I'm not sure, i have to get a gauge when i get my new fuel pump setup.
