How badly is if u dont installed dual springs in there proper pressure
Old 11-17-2011, 08:28 PM
El_TransAm98's Avatar
Default How badly is if u dont installed dual springs in there proper pressure
I just put them like that..or is more importatn to seat the springs in there proper spring pressure?? Or is not the bad cuz a guy says is the same thing nothing wrong occursi have the patriot dual springs..what u guys recommend me to send them have them seat proper pressure?.thanks in advance
Old 11-17-2011, 11:14 PM
01ssreda4's Avatar
What cam are you running? What rpms are you going to turn? Heads stock?
Old 11-18-2011, 07:26 PM
crainholio's Avatar
When you don't know what you're talking about...it's impossible for other people to know what you're talking about.
Short answer: take the heads and springs to a machine shop and give them a copy of your cam's specs as well as the springs' specs.
Old 11-18-2011, 09:31 PM
SweetS10V8's Avatar
So true, I was a little lost for words. I will really help you when I understand what you are trying to ask......
Old 11-19-2011, 11:02 PM
Well my question is of there a problem when springs are not seated correctly in there proper spring pressure??? Cuz i just intalled them with a tool not measuring anything..cams is 236/242 .611/.617 with 5.3 heads ported with 2.0 valves
Old 11-20-2011, 01:22 AM
ZeeOSix's Avatar
I think what he's saying is that he just installed the springs without checking the installed height. if there wasn't any valve work done on the heads, then the install height will most likely be within the GM spec of 1.800 +/- 0.020".
If there has been valve work done (ie, valves & seats reworked and/or valve stem heights adjusted), then they might not have the exact installed spring height.
Old 11-20-2011, 06:52 AM
crainholio's Avatar
Thanks for translating. I'm not sure what "2.0 valves" are, so it's still tough to give any meaningful info presuming they're not factory pieces and stem height is unknown.
If measuring things isn't his bag, he'll be screwing up the lifter preload and making for lots of fun reading.
