She blew!!!!
valves are still on the keepers and they are bent to ****
Do youself favor while you are in there and replace the JUNK standard LS1 starter with the updated truck style that uses two long bolts. So you don't suffer from the cheap azz standard starter housing breaking off then twisting the outter starter bolt boss off the block.
Hell go buy a Ford!
Hell go buy a Ford!
OP it sounds like a fluke thing which happens I'd throw a new shortblock in with a decent cam and have at it.
crank but that doesn't mean that the bolts didn't stretch. When this happens
the bearing clearances open up and start wearing the bearing shells out real
fast. Each time the crank turns the piston travels further north until it hits the
valves and or head. Impossibly trying to compress valve heads(after breaking)
or the forces exerted on the rod when crashing the head causes the piston
and rod to part ways either in the beam or at the wristpin. Even at normal
cruising speeds this will obliterate an aluminum block. Very sorry to hear of
your misfortune and best of luck reloading.
Glass in the cylinders??
Working on the car w/ the intake off and the heads unsealed:
