Milling PRC ls6 stage 1 heads????
I currently am running a stock shortblock with a ms4 cam and stage 1 prc ls6 heads. I am wanting to mill the heads done to achieve a higher compression ratio. What should I mill them too?? I will be getting a custom grind cam from PatG after they are milled. Let me know here I need some advice. I will be running nitrous also.
LS1Tech Premium Sponsor
In an ideal world, you'd coordinate the head milling and cam selection together to avoid limiting yourself on cam size selection.
What are your goals for this swap? is it going to be a top-end screamer, bottom-end torque monster and rock crawler, etc? Let us know some details and we can get an idea of the size of cam you'll be running, and thereby make a recommendation on the milling
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Closed on the weekends, but we'll be open again tomorrow morning at 9:30am Central time!
__________________
