Oil dipstick bolt size
Old Dec 5, 2011 | 12:34 AM
6SIX6's Avatar
Default Oil dipstick bolt size
I need to know the bolt size and thread pitch for the bolt that holds the dipstick in where the header bolts are. I thought it was a M10 but its too big for it. If anyone knows please let me know
Thanks
Old Dec 5, 2011 | 11:12 AM
6SIX6's Avatar
Anyone?? Did I put this is the wrong section by any chance? I need to find out ASAP
Thanks
Old Dec 5, 2011 | 12:38 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Should be M10x2.0
Old Dec 5, 2011 | 02:31 PM
6SIX6's Avatar
I tried a M10 and it seemed to big for the heads. It looks to be the size of a header bolt but i cant even remember the size of that at the moment.
Old Dec 5, 2011 | 06:14 PM
dr_whigham's Avatar
The Scammer Hammer
Header bolt is an m8 for sure, and I BELIEVE a 1.25 pitch.
Problem I had at the hardware stores was the bolt head itself. When I installed my LT's I found out I was missing a manifold bolt completely, and that the dipstick tube bolt wouldn't fit.
The header bolt is a m8x1.25 and a 30 length, but if you notice on the factory pieces at the tip of the bolt, the first 5 mm of thread is bare. A 30 is too long, and you'll need a 25.
For the dipstick tube bolt, instead of messing with it all over again, I just ground down the built-in flange on the bolt head itself and it worked like a charm.
I'm guessing you lost your though, so this doesn't help at all, huh?
Old Dec 5, 2011 | 06:17 PM
6SIX6's Avatar
I never got one with the motor when I got it. I got a few bolts kickin around the garage so I guess i will see if one fits but I still would rather know the right one eventually. I will try and M10 again too
Old Dec 5, 2011 | 07:27 PM
Paul Bell's Avatar
That's MISTER MODERATOR
GM parts book says M10 x 1.5 x 25 pointed
Old Dec 6, 2011 | 12:07 PM
dr_whigham's Avatar
The Scammer Hammer
By 1.5 it is then. I knew I'd screw it up somewhere.
The hardware stores have them, but the bolt head itself is bigger, that was my problem.
I would just post a wanted ad in the sale section and get a factory piece.
Old Dec 6, 2011 | 01:02 PM
6SIX6's Avatar
I will try the M10 again when I go work on it again wednesday. I forgot to mention I have patriot heads so that might be the issue to it not working to.
