Crank replacement or Tapp the Snout
How far is it broke off in the snout?
I would try to drill it out, start with a small bit then work your way up.
Start with a 1/4" bit and work your way up. I'm sure that ARP bolt is harden.
May try some titamium bits. Sometimes you can drill all the bolt out and still save the threads.
GL.
