Tr224 + Ls6 Springs
https://ls1tech.com/forums/generatio...w-springs.html
Do yourself a favor and buy the PSI 1511 Maxlife springs. They're the best beehive spring on the market, cheaper than PAC 1518's, and have a 0% failure rate. On a low lift cam like the TR224, you could run the PSI's for 100,000 miles without any issues assuming correct pushrod length was measured/installed.
They might have a low failure rate but I promise you its not zero!
