Engine block may have cracked, could low coolant have been culprit..
Ok this might be a silly question but ....... I think I actually may have cracked my block.
When I looked at my coolant...the resevoir was bone dry and the radiator is about halfway or a bit less than half way...
my question is: could this amount of coolant or lack there of, have been insufficient enough to make the block crack? After reading symptoms of a cracked block ... I seem to be experiencing just that. This weekend hopefully I will find out for sure.
I take care of 4 cars now and completely lost track of the camaro's coolant level
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Are you having any overheating issues? Have you checked to see where the coolant has been going? Any smoke? Do a compression sest, and leakdown to be sure its not just a headgasket. Also check for a cracked resivoir, which may be able to drain down the radiator.
Blocks dont just crack for no reason. have you been beating it?
I have check fuel pressure and its 60psi right until it dies. Would a headgasket cause those type of issues to happen?
also the car was idling great until right before I heard a kind of metallic "pop" then it idled nasty then just died. The engine light is NOT on and I scan for codes. I used 2 programs and NONE found any active DTC codes BUT there were 5 "stored" codes, whatever that means.
1. P0135
Powertrain: HO2S Heater Performance Bank 1 Sensor 1
2. P0154
Powertrain: HO2S Circuit Insufficient Activity Bank 2 Sensor 1
3. P0327
Powertrain: Knock Sensor Circuit Low Voltage
4. P0332
Powertrain: Knock Sensor 2 Circuit Low Input (Bank 2)
5. P0704
Powertrain: Clutch Switch Input Circuit Malfunction
Damn this is sucky
