LS7 coils, Work with LS1?
Although LS7 coils are "better" than LS1 coils, they will not directly swap in. The most powerful coils you can use are the heat-sinked truck coils. You may have some power and/or engine response improvements when moving to them. It's all here: https://ls1tech.com/forums/generatio...ke-sticky.html
LS1tech SEARCH is your best friend here.
As coils are an external part, you shoulda posted this in the external engine forum, not the internal.
It's all here guys: https://ls1tech.com/forums/generation-iii-external-engine/1249222-truck-ignition-coil-upgrade.html
Side note: Coils do not "wear out" or have diminishing performance over time and use. They work or they don't. Occasionally, a coil can be intermittent, it work fine now, stops working altogether later then works perfectly fine again later. If your existing coils are working, just keep them. And DON'T make the mistake of buying MSD LS style coils. They fail.
