Solid roller lifter or hydraulic roller lifter
Old Dec 12, 2011 | 02:22 PM
abrahamkay's Avatar
Default Solid roller lifter or hydraulic roller lifter
I have a Comp Cams #54-428-11 and was wondering if I could switch from the hydraulic roller lifter to a solid roller lifter and not do any damage to anything? I have a built 347 from Xtreme Horsepower. It has a GM stock crankshaft, Eagle H-beam 6.125" connecting rods with ARP 8740 rod bolts, forged Mahle pistons, Clevite77 race bearings, ARP main bolts. My heads are 241 ported.
Old Dec 12, 2011 | 06:26 PM
crainholio's Avatar
You will want to swap in a cam designed for solid roller lifters.
And you'll have trouble fitting suitable springs to 241 heads without having the spring pockets machined to accept larger diameter seats.
Old Dec 12, 2011 | 06:51 PM
SweetS10V8's Avatar
Why do you want a solid roller? This isnt the 90s, many advances have been made with hyd rollers, and very very few people need solids anymore.
What rocker arms are you running?
Old Dec 12, 2011 | 06:57 PM
MikeFSKSpeed's Avatar
Comp cams has a really great short travel hydraulic lifter that drops right in place for an LS/Chevy SB. I've had great luck with some higher revving LS Engines and I sell a ton of them.
Old Dec 12, 2011 | 07:10 PM
SweetS10V8's Avatar
Ive used them as well, #16850 right? (or something similar for the drop ins)
Old Dec 12, 2011 | 07:28 PM
Well the ones I'm talking about are these... 875-16:
http://www.skspeed.com/ProductDetail...uctID=C5687516
Old Dec 12, 2011 | 08:20 PM
nastychevelle's Avatar
Why would anyone want more horsepower? That is crazy talk!
Old Dec 12, 2011 | 08:23 PM
While advances in cam profile and lifter design have allowed very radical hydraulic designs, a solid roller will always allow the most extreme lobes and quick ramp speeds, which require heavy spring pressures that would collapse a hydraulic lifter. While many can make great power with a hydraulic, the solid ain't dead yet!
Old Dec 12, 2011 | 09:22 PM
abrahamkay's Avatar
I have the Comp Cams Magnum 1.75:1 roller rockers along with the magnum push rods. The valve springs I have in the heads now can go up to .600 I have no clue to if the hydraulic roller lifters are stock or not. I reused them from when my ls1 blew a rod on my move from texas to missouri (ARMY)
Old Dec 12, 2011 | 09:34 PM
SweetS10V8's Avatar
Ahh, those are old news..... The new ones only have .050" travel in the entire lifter and are awesome for valvetrain stability. Just have to be accurate on your pushrod length when using a non adjustable rocker setup.
Here; http://www.compperformancegroupstore...Category_Code=
IF it were still back in the days of your Chevelle, I would agree with you. I was taught that solids were the ONLY way to go since I started learning about hotrods as a teen. But over the years I have seen first hand the differences. Solids have their place; .700+ lift 260+ duration drag race only cars which 99% of people do not have.
For most forum users a solid roller is not a good match for their combination, and wont make much more power than an equivalent present day lobed hyd roller. It just gives people a lot more to screw up, and they do a good job of it on their own with out having to set lash. Ive run a 230s/240s solid roller setup before and it didnt make any more power than the equivalent hyd roller. Solids do help with valtrain stability but again todays valetrain components avaliable to the public can work very well when properly matched.
Old Dec 13, 2011 | 09:35 AM
Havoc40's Avatar
This. Although, purpose built short travel hydraulic lifters do change the game a bit, if built properly. You can add me to the list of solid roller fans. Nothing beats the stability and response from a solid valve train IMO.
Old Dec 13, 2011 | 10:02 AM
Ahhh those race lifters posted above are indeed awesome. I don't sell them as much but our engine shop orders a few in at a time for LS builds they do.
Closest you can get to a Solid without actually going solid.
And I personally love Solid Roller for certain applications. I just built a Gen 1 SBC 383 that made an easy 578hp on pump gas with a smaller solid roller and AFR 210s. With the stud girdle the top end is dead stable.
Old Dec 13, 2011 | 05:03 PM
v8pwr's Avatar
To answer the OP's question most likely not. There are usually special "ramps" designed into solid profiles that are less aggressive initially to take up slack then the solid profile can become far more aggressive. Hydraulic profiles don't need those "ramps" because the lifter takes up the slack. It would be best to call Comp but you need to get the right person who knows what they're talking about.
Old Dec 13, 2011 | 06:57 PM
abrahamkay's Avatar
Default Kinda off my orginal question
Do I really need the valve lifter tray or can I just get rid of it?
Old Dec 13, 2011 | 07:21 PM
crainholio's Avatar
Upgrade to link-bar lifters and the plastic trays become unnecessary.
Old Dec 13, 2011 | 08:10 PM
abrahamkay's Avatar
What will I gain going with a linked lifter?
Old Dec 14, 2011 | 04:21 AM
crainholio's Avatar
If that is not self-evident, it's time for more reading and less writing.
Old Dec 14, 2011 | 04:54 AM
subhumanzz's Avatar
Love my solid roller.
Old Dec 14, 2011 | 04:56 AM
crainholio's Avatar
Info on link bar lifters is very hard to find, so here's a link:
http://lmgtfy.com/?q=link+bar+lifter+advantages
Old Dec 14, 2011 | 05:59 PM
JPH's Avatar
JPH
You would probably have better luck/results by changing out that cam profile to something BIGGER if you are wanting more hp/rpm and NOT having to deal with hyd roller lobe with a solid roller lifter.
