Stock Head LQ4 Cam Recommendations
Few things have changed. Here are mods. I'm looking for an off the shelf cam that has proven itself in the LQ4 with a basic p&p stock heads.
TH350 Trans with 4k stall
3.73 gears
GBody Swap Headers
LS6 Intake
Ported TB
Not a DD drivability doesn't matter.
What would be a cam that would work well with this setup. I'm reading the ms3/4 won't work well on the lower compression. Not really looking into doing anything custom just something I can buy that would work well. Would also like something that if I did do a head swap it would still be good but flow better and make some more power.
I've searched and can't find much info on stock lq4 heads and cam options. Seems people switch them out quite a bit.
Thanks,
3.73 gears
GBody Swap Headers
LS6 Intake
Ported TB
Thanks,
TTT, Few things have changed. Here are mods. I'm looking for an off the shelf cam that has proven itself in the LQ4 with a basic p&p stock heads.
3.73 gears
GBody Swap Headers
LS6 Intake
Ported TB
Need suggestions. Not a DD drivability doesn't matter. Not really interested in the MS4
3.73 gears
GBody Swap Headers
LS6 Intake
Ported TB
