Are these reusable?
Old Dec 24, 2011 | 09:59 AM
softballnrd27's Avatar
Default Are these reusable?
I am trying to build my 6.0 on a budget and I am concerned with the pistons. I don't have access to a bore guage or an outside micrometer so is there a way I can measure the clearnace with feeler gauges? If so what is the max?
All this might be for nothting, here are the pictures of the pistons:
Here is the worst one IMO:
Old Dec 24, 2011 | 10:49 AM
ljsracing19j's Avatar
Based on looks i would say throw them away. But take some time and clean them up then repost pictures...
Old Dec 24, 2011 | 11:23 AM
raven154's Avatar
Looks can be deceiving. The right way to do it is to get out a mic and start measuring.
Old Dec 24, 2011 | 11:33 AM
02ws.sik's Avatar
Can you reuse a condom
Old Dec 24, 2011 | 06:45 PM
LS1MCSS's Avatar
You won't do it but once.
Old Dec 25, 2011 | 01:01 AM
Paul Bell's Avatar
That's MISTER MODERATOR
I know you're on a budget but measuring pistons and bores is one of a few mandatory steps to rebuilding an engine. If you re-use these pistons without properly measuring everything, you're really not doing a rebuild. In that case, why bother even starting the job?
Put things on hold until you have the funds to do it correctly-or don't do it at all.
Old Dec 25, 2011 | 05:00 AM
RezinTexas's Avatar
A .001 dial bore gauge can be had for cheap.
http://www.amazon.com/Anytime-Tools-.../dp/B000I8QVES
I would not use this one to attempt an accurate measurement of your main bores, but it should be ok for the cylinder bores.
Old Dec 25, 2011 | 10:14 AM
Trust me, I wouldn't use these without a proper measurement 1st. If that means I have to take it to a machine shop 1st then I would. I am looking for opinions from some people with more experience with LS engines. I just wanted to see if there was a way for me to measure with feeler gauges to see if they were even close.
I am more than likely going to hold out and go forged psitons and new rods anyways so this will probably all be a mute point.
Old Dec 25, 2011 | 10:19 AM
Damian's Avatar
LSX Mechanic
Are those LQ4 or LQ9 pistons? Can't tell from the pics. I've got a few LQ4 pistons you can have cheap if you need some.
As others have said, measurements are mandatory when putting an engine together. Even a budget build. Never assume anything.
Old Dec 25, 2011 | 02:35 PM
Paul Bell's Avatar
Hey softball, sorry if I sounded a bit like a di-k, I didn't mean too. Good luck with your project!
Old Dec 25, 2011 | 03:18 PM
Not at all, I wanted to put it out there for those types of opinions so no worries. Some of the stuff I have read is from left field.
Old Dec 25, 2011 | 03:20 PM
LQ4 pistons
Old Dec 25, 2011 | 05:45 PM
noice's Avatar
Yea I got some LQ4 pistons I don't want either. Went with +.005" Flat top forged pistons. I'm sure there is quite a few people on this board that would be willing to part with them for next to nothing if they haven't already thrown them out.
