Cam retainer plate broke
Old Dec 31, 2011 | 10:53 AM
stewdy1's Avatar
Default Cam retainer plate broke
Any one ever heard or seen this, only had five miles on motor, and motor is now junk
This is the older style plate with older style bolts not the countersunk ones
Old Dec 31, 2011 | 11:19 AM
LSxChevelle's Avatar
Wow...never seen that! Did you shave the bolt heads? If so, are there marks on the back of the cam gear?
Old Dec 31, 2011 | 11:24 AM
Don O.'s Avatar
Default Too bad
I have seen this before when either someone did not tighten the cam retainer bolts and they backed out and hit the timing gear or there was not enough clearance between the gear and the bolts.
Some aftermarket timing sets need to be checked for clearance.
Don
Old Dec 31, 2011 | 01:06 PM
stewdy1's Avatar
The bolts look like that from the back of cam gear hittin them and its all stock timing gears
Maybe I tightened the retainer bolts too tight and broke it idk
Old Dec 31, 2011 | 01:43 PM
crainholio's Avatar
What did you torque the retainer plate bolts to?
Old Dec 31, 2011 | 07:31 PM
S10xGN's Avatar
Dayum! Are all four bolts sheared off?
Prolly until they wouldn't turn, then another round...
Old Dec 31, 2011 | 08:04 PM
parks450's Avatar
Looks like thebbolts were torqued to much
Old Jan 2, 2012 | 05:14 PM
N20neenee's Avatar
Torque for the old-style camshaft retainer bolts are 18fts
Old Jan 3, 2012 | 11:40 AM
getusumws6's Avatar
torque specs are here for a reason....
