Vrx3 valvespring decission
Old 01-05-2012 | 01:48 PM
Ole Z28's Avatar
Default Vrx3 valvespring decission
Hey everyone,
Im finally doin a camswap on my 99 Z28, and I figuered the vrx3 would suit the best for my needs.
I was wondering what people who allready have this cam use for Valvesprings or what you guys would suggest?
The camspecs are:
226/228 .585/.588
112 or 114 LSA not sure yet.
Thanks for your help!
Old 01-05-2012 | 04:19 PM
supersick99z's Avatar
I'd use comp 918's if I were you. Relatively cheap and they will work with that cam.
Old 01-05-2012 | 08:53 PM
poltergeist 02's Avatar
i would go with pac springs 1218's or 1518's.
Old 01-05-2012 | 08:56 PM
redbird555's Avatar
i agree on pac 1518's or psi max life. vengeance also recommended him a c5r chain and comp 850 lifters? Normally i wouldnt second guess a sponsor like this but that seems a little overkill in my mind I say use new ls7 lifters and an ls2 chain and call it a day its not like were using a >.600 lift cam here. but hopefully someone can throw in their .02 also
Old 01-06-2012 | 12:02 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
Chekout the prc .650" spring kit, the double spring is typically safer and should have a nice long life!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 01-06-2012 | 02:40 AM
1999BlueTA's Avatar
To the OP, there's a brand new set of pac 1218s fs in the parts classified for $125 shipped I would jump on those if I were you!!!
Quick Reply: Vrx3 valvespring decission
