PTV clearance question
Old Jan 11, 2012 | 09:39 PM
jtaylor16's Avatar
Default PTV clearance question
Just picked up a used cam its a Bullet 234/238 .650/.650 w/ 112 lsa. Im very concerned about the ptv clearance. I plan on running the cam with my ported 241 heads, I know if I deck the heads ill be playing with fire but if I keep the stock deck height and stock head gaskets should I still have enough clearance without having to fly cut the pistons?
Old Jan 12, 2012 | 12:15 AM
3rdCoastPowerSports's Avatar
i have the same duration @ .050" 234/238 cam in my car with ported 241's,,, When i measured i had .102" PTV clearance intake and .110" PTV clearance exhaust. min should not be less than .080" intake and .100" exhaust... you should be good to go.
Old Jan 12, 2012 | 02:14 AM
bww3588's Avatar
Nobody can tell you for sure. Every engine is different. I would check it to be sure, if you don't and crash the valves, that's your own fault.
Old Jan 12, 2012 | 10:11 AM
jtaylor16's Avatar
thanks 3rdcoast, ill prolly clay a piston just to be sure when it goes in
Old Jan 13, 2012 | 05:33 PM
JPH's Avatar
JPH
Good answer and smart idea.
