LY5 AFM Delete
Old Jan 20, 2012 | 08:21 AM
godlyxdan's Avatar
Default LY5 AFM Delete
Starting my 5.3 soon, Tax Refund Check
So I found a nice looking, Low Mile, Cheap LY5 from an 07 Avalanche
Should be right around 315/335 Stock so thats more than enough to start with for my little Blazer lol
My question is, since it is an 07 it has AFM, whats the fastest and cheapest way to delete AFM? Any sponsors here sell a kit?
I plan on running a 224/228 Cam (nice choppy Idle) so I will end up needing more than the .500 lift that AFM allows for
Thanks, Dan
Old Jan 20, 2012 | 08:40 AM
mark21742's Avatar
What is AFM?
Old Jan 20, 2012 | 10:01 AM
godlyxdan's Avatar
Active Fuel Management
Old Jan 20, 2012 | 10:17 AM
mark21742's Avatar
If you run your stock computer from your 5.3 that should take care of it
Old Jan 20, 2012 | 10:40 AM
godlyxdan's Avatar
Im getting the motor complete with its original PCM which is set up for AFM, What ive learned about AFM (DOD) is that there is hardware that needs to be replaced for it to fully go away without leaving problems (Oil Pressure Problems) at least that is what previous threads I dug up on here have led me to believe
Old Jan 20, 2012 | 10:54 AM
mark21742's Avatar
Oh ok. I thought ot was all in the computer programing. You might try contacting a tuner....they "should" know what else needs changed besides the program in the computer
Old Jan 20, 2012 | 11:05 AM
godlyxdan's Avatar
well you can have it tuned out but the hardware restrictions (no cam with more than .500 lift) will still exist unless you swap out some stuff. Which is why im looking for a good kit that includes all of that lol
Old Jan 20, 2012 | 11:08 AM
mark21742's Avatar
Oh my, I had no clue lol....well I'll sit back, listen and hope to learn more on this lol
Old Jan 20, 2012 | 11:13 AM
godlyxdan's Avatar
im along for the ride too man, Im just waiting for someone who has dealt with deleting DOD/AFM to chime in and tell me what they used to do it
Old Jan 20, 2012 | 11:53 AM
mark21742's Avatar
I wss reading on another site.
The FAST LSXRT intake is worth 20rwhp over your intake, its a simple swap. An exhaust system (Headers/catback) are worth another 20hp or so. Comp Cams has some AFM specific cams avaliable that will drop right in, or you can change the valley pan, lifters, and trays to delete AFM and that will allow you to run over.500lift
Old Jan 20, 2012 | 11:54 AM
mark21742's Avatar
But, id skip on the Fast intake for $1000+ lol....
Old Jan 20, 2012 | 12:33 PM
godlyxdan's Avatar
ya I read that too, actually on that same site (performancetrucks) there is a sticky thread that has part numbers for everything you need to do a full delete so I guess I found my answer. Thanks for your help!!
and ya im going with an LS6 intake not a 1000+ Fast lol no need for that much
