243 milling n comp ?'s
Old Jan 25, 2012 | 05:36 PM
ksk1980's Avatar
Default 243 milling n comp ?'s
Blocks at machine shop n pistons r supposed to b here friday .its a 6.0 bored. 040 and running flat tops. Question is whats gonna be my comp ration if i have the 243's milled. 01 just to make sur theyre cleaned up and try n raise comp ratio a little bit at the same time
Was gonna run my ms3 but its screwed. So thinking of running the 233/239 .anyone running this cam in a 370-371? thoughts on it?
Old Jan 25, 2012 | 05:40 PM
ksk1980's Avatar
Also is the. 603 on the exhaust side gonna cause a ptv issue with milling the heads. 010 and what head gasket should i run?
Old Jan 25, 2012 | 08:42 PM
A.R. Shale Targa's Avatar
Stock head gaskets, -.010"milled 243s @ 63cc, and 371CID should be about
11 to one compression...maybe a tad more but the 233/239 cam should run
well with this combo on 93 octane.
Old Jan 25, 2012 | 08:46 PM
3rdCoastPowerSports's Avatar
233/239 cam likes compression
Old Jan 25, 2012 | 09:16 PM
ksk1980's Avatar
Any ptv issuses sticking out like a sore thumb? Flat tops no reliefs
Old Jan 25, 2012 | 09:22 PM
you might be close but i think you will be good, not positive though. best thing to do would be to measure. Im sure there are more than a few people on here that are running the same setup as you and have checked their PTV. Hopefully they will chime in.
Old Jan 25, 2012 | 09:36 PM
ksk1980's Avatar
Yeah hope they do chime in. HINT HINT,!!!! Just dont want any issuse just check to make sure clearance is ok and bolt it together. No flycutting or sending back cams .
Old Jan 26, 2012 | 01:57 PM
ksk1980's Avatar
Anybody running this set up?
