Help my figure out compression ratio
Old Feb 1, 2012 | 08:29 AM
TXSZ66AVLANCHE's Avatar
Default Help my figure out compression ratio
5.3 overbore to 3.799, flat top pistons, stock MLS head gaskets, and 862 heads.
Thanks !
Old Feb 1, 2012 | 08:47 AM
mark21742's Avatar
If you get your rod length and chamber cc you can use WWW.wallaceracingcalculators.com
Old Feb 1, 2012 | 09:30 AM
Hmmm 0.041 head gasket
Your displacement is 328.45 CID
The Compression Ratio is: 10.81
0.051 head gasket
The Compression Ratio is: 10.55
