stroker motor
Old Feb 4, 2012 | 04:24 PM
tjb406's Avatar
Default stroker motor
i am thinking about building an lq4 with a 4.00 inch stroke crank is there any clearancing that will need to be done to the block or special cam that will be used. i have built several big and small block chevys this will be the first ls style that i do. thanks for any info.
Old Feb 5, 2012 | 03:35 PM
tjb406's Avatar
wow no one
Old Feb 5, 2012 | 03:45 PM
KCS's Avatar
KCS
Moderator
Originally Posted by tjb406
wow no one
I know this isn't the first time someone has asked this same question. If you haven't done so already, you should find your answer by using the "SEARCH" function.
Old Feb 5, 2012 | 10:13 PM
Soul Crusher's Avatar
This set up makes a 370 ci engine right? Pretty much any 370 iron buildup thread should be helpful to you.
A shorter answer to your question is: "not really"
Old Feb 6, 2012 | 06:36 AM
KCS's Avatar
KCS
Moderator
A 370 is typically a stock stroke and a 4.030" bore.
A 4.0" stroke in an LQ4 should make at least 402ci.
Old Feb 6, 2012 | 05:22 PM
RARON455's Avatar
Its not that different, you dont have to run a special cam lifters or anything like that. Some aftermarket stroker kits actually have the clearance built into them. I clearanced my block for the crank, but My rods were not an issue at all. You will need to space your windage tray up, I just used washers. Be sure to get a cam and heads to take advantage of the build, that will make the most out of the extra cubes.. Hope this helps.
Old Feb 6, 2012 | 08:16 PM
tjb406's Avatar
thank you raron was going to do 4 inch stroke with .030 bore ls3 heads and intake.
Old Feb 6, 2012 | 09:05 PM
SOMbitch's Avatar
Should be a nice 408
Old Feb 7, 2012 | 05:13 PM
tjb406's Avatar
nice 408 in an s10 xtreme
