Custom EPS Cam + 243 build. Look inside
Stock rockers with trunion upgrade
243 heads, possibly AI ported, or hand ported by Chad Speier
LS3 hollow int valves
PSI Xceldyne Springs
Lashway Pushrods
C5R Timing Chain
Ported LS6 Oil Pump
Thinner MLS head gaskets
Springs, undecided. I want lightweight but I'm kind of gun shy on beehives... Maybe PSI Beehives.. or I may stick with trusty PRC Dual Gold Xtremes...
LS6 Intake already have
LS6 Valley Cover
LS2 Lifter Trays
??? throttle body
SLP 85mm MAF already have
FTP 95mm? airlid
Chrs1313 Ram Air, A/C version
Ace Racing Stg2 Trans - already have
FTI 3800 stall...
Nitto DR's on Heavy Z06 replicas for now.
150 shot on occasion
Comments, suggestions, part numbers?
I'll just say this, I'm definitely a fan of baby cams
Anyway, here are the parts I've purchased, am I missing anything? My brain isnt working tonight...
Head Gaskets
Head Bolts
GM Water Pump Gaskets
Fel Pro Intake Gaskets
GM Timing Cover Seal
GM Front Seal
GM Harmonic Balancer Bolt
GM HD LS2 Timing Set
Pac 1218 Springs
Trickflow 7.425 pushrods
Plus the heads, cam, etc...
Dude my truck is still in the shop or I would have been over to get it! Im gonna kill the guy who is supposed to be fixing it...
I will def come pick it up when I get home here in a week tho!
I'm gonna run the stock one til it ***** out, then order up an FTI 3800 stall to throw in front of your old trans.
12551933 this is a small gasket used on the coolant cross over or block off
12602541 cross over o-ring used in conjunction with gasket above
Ive pulled some off with both being used and some with just one or the other....GM must be very inconsistent or someone else was there before me. You need 4 of each part number, they're cheap anyways.
