engine options
Old Feb 9, 2012 | 11:59 PM
+badss+'s Avatar
Default engine options
hey guys,
im looking to put together a 370-408 long block, i have 6500 to do it with.
it will be going into my 02 SS mated with a d1sc procharger with 10-15 psi. think that it can be done? im talking 6500 for long block not the procharger..
thanks.
Old Feb 10, 2012 | 01:28 AM
technicalninja's Avatar
It looks like you can damn near purchase it built for that type of money.
http://www.texas-speed.com/p-655-tsp...ong-block.aspx
If you can do the assembly work yourself and have a good machine shop available then your budget should work fine.
You might want to contact a few of the vendors and get some quotes.
Good luck
Old Feb 10, 2012 | 01:51 AM
01ssreda4's Avatar
Id do their 408 shortblock and a set of 317s worked over by Advanced Induction if I was you.
Old Feb 10, 2012 | 03:14 AM
BOBS99SS's Avatar
Captain Double Post
^ cant go wrong there
Old Feb 10, 2012 | 06:23 AM
TransAmcoupe98's Avatar
370 over the 408 for boost.
Old Feb 10, 2012 | 03:34 PM
+badss+'s Avatar
What you guys think of aes's 390 engine with ported 317 heads, what comp for 15 psi?
Old Feb 10, 2012 | 08:28 PM
COPO9560's Avatar
AES 390 is designed for boost - great choice. #2 would be a 370.
For 15 psi, I would look to aftermarket with thicker deck - you are at the ragged edge of stock style heads and any tune issues could get you in trouble. I'd say go L92 or LS3 over ported 317's if you can back down on boost desires - LS3 intakes are pretty cheap as well and flow better than most.
For 15 psi, better option would be the the F1A Procharger if you can stand the noise. Not a lot more to buy and will be better suited for higher hp application. You will need FMIC and should consider Aster mount to avoid belt slip problems.
Long block engine can probably be completed for the $6500 range with a GM casting for head. AFR, TFS or MAST heads build will raise price. Balance of your existing mods will match boosted engine pretty well.
Old Feb 10, 2012 | 09:31 PM
King Nothing's Avatar
9-9.5 comp ratio. Any pics of your SS?
Old Feb 10, 2012 | 11:36 PM
+badss+'s Avatar
On my iPhone ATM but if you look at my profile I have a build thread from first wave of mods
Old Feb 10, 2012 | 11:38 PM
+badss+'s Avatar
I'll check to see what the cost of l92"s will run and maybe run just 10-12 psi for time being
Old Feb 11, 2012 | 12:04 AM
bww3588's Avatar
A guy on here sells take off heads as he gets them. I would look into a set of lsa heads. They are designed for boost.
Old Feb 11, 2012 | 12:13 AM
sepsis's Avatar
I'm no expert, but wouldn't you need forged internals for that kind of boost?
Old Feb 11, 2012 | 02:08 AM
bww3588's Avatar
I was thinking that too.
bww3588's Avatar
At the very least, forged rods and pistons.
Old Feb 11, 2012 | 09:57 AM
01ssreda4's Avatar
Local guy has one and likes it.
Not on a stock short block you won't, at least not for very long.
Old Feb 11, 2012 | 08:01 PM
+badss+'s Avatar
where is this not forged bottom end talk the 390 is forged internals
6.0 Iron Engine block
Callies Compstar C-series crankshaft 3.825" stroke
Callies Compstar H beam connecting rods
CP Pistons 2618 forging -15cc D dish
NPR gas nitrided piston rings, napier 2nd ring
King HP bearings, durabond cam bearings
All parts are thoroughly cleaned before assembly
Crankshaft balanced and polished
Line honed main journal
Resurfaced cylinder deck
Torque plate honed bores
Assembled in our clean, dedicated, engine assembly room.
390ci shortblock package with the addition of
-Ported '317' GM castings, assembled with stainless valves and Patriot Gold dual springs
-ARP head studs/ ARP main studs
-GM MLS gaskets
-Comp Cam/LS7 lifters
-JP Performance double row timing chain
Heads are assembled, installed, camshaft degreed
with 10 psi? what you think.
Old Feb 11, 2012 | 08:21 PM
double check your comp ratio and i think you should be good. what cc are the heads?
Old Feb 11, 2012 | 10:00 PM
+badss+'s Avatar
don't know yet til i talk to Fraser on Monday i think they are 72cc stock.
also last time i talked with Fraser he said he would set it up for 10-1 cr.
Old Feb 12, 2012 | 06:16 PM
as long as it's forged it should be ok . . . be better if it was closer to 9.5 so you can turn that boost up
