? for you guys that have been there done that with heads
The latest plan was to get some PRC 5.3L stage 2.5 heads with a 228 cam. I was going to go this route because its a great DD capable setup and my tuner recomemded it on a budget.
Im wondering from you guys if I will be kicking myself down the road for not spending more on a set of heads?
I understand the prc cnc'd 5.3s are great and raise compression but am I rushing into this? Should I be going for some TFS 215s or something?
I also understand this might turn into a 5.3 vs 6.0 debate
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
Turd Gen Guy
Prc 2.5 5.3 heads make decent power for cost vs. horsepower.. But if you have a ls1 id look into the tfs as cast ls1 220 and send them to brian tooley and let him work some magic and touch them up. An aftermarket casting head will take you further than a gm casting head.. BUT a AI/T.E.A. ported ls6 head would be hard to beat... If your on a budget tho just get the 2.5 5.3 heads... But they wont hold a candle to a ported ls6 head or a aftermarket casting head
The ls6 your talking about are 243s correct?
I also understand this might turn into a 5.3 vs 6.0 debate![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
Unless you are trying to make over 450 rwhp I would say got with the prc 2.5 5.3 heads...the way I look at is the xtrA $ you spend on trickflows heads and new rockers you could of bought prc 5.3 heads, cam, and an ls6 intake...but if $ isn't a problem get the trickflows or afrs for the most power potential...
Also 317 heads have a bigger combustion chamber which will lower compression ratio...people usually only run the 317s on nitrous or turbo/supercharged cars...good luck man
formerly twolow02fransen (2014-1-2)
i was goin to buy PRC 2.5 LS6 heads but changed my mind and went with a set of AI 226cc 243 heads and custom grind reason because of the power numbers the AI setups have been putting down. plus i hear there heads arnt what there cracked up to be you get what you pay for IMO.
I wasn't trying to put your **** down, I just can't see spending over $2,000+ on heads and slapping the stock rockers on there. Might as well spend an extra $400-500 and get a good set. It's just something I couldn't do just to save a few bucks. Not to mention is good for some extra HP.
Turd Gen Guy
All roller rockers are heavier than stock rockers, but not as strong as the stock ones either. Stock rockers with a trunion upgrade are more than adequate. Setting everything up correctly and achieving the correct geometry are key to making the stockers work well with a big cam.
Lots of info in this forum if you search...
