worn ms4 cam
Why? It was a Comp...ffs get off my sack.
What I'm saying, because apparently you don't understand, is that Comp Cams uses garbage cores and that they go bad on ALL applications.
I suppose all things in this world are going to wear down expecially in an environment of friction and vibration.
I always replace the stock lifters with new lifters when I do a cam swap. I hear it all the time, "they dont have very many miles on them" and I say "yeah, but they are 12 years old, its not fine wine".
My car had the exact same issue a few months back... Put a new cam and lifters in it and a few thousand miles later it happened again, only one lobe each time. Turned out to be worn prc springs. Put a new set in along with new lifters and its been going strong since.
You will wipe out a flat tappet cam if you are not careful with your oil selection. They have to have the zinc.
All Valvoline ZR1 racing oils have the zinc packages, as well as a few other oils.
Just saying it might have something to do with it.
You have a picture of the lifter?
I had a G5x2 cam do the EXACT same failure last year. 11 of the 16 lobes had scores on them, many of those looked like the one pictured. The remaining 5 had a visual color difference but not scored.
Car had 16k when I bought it, cam crapped out by 18k. Mod's were on the car sometime arround 12k. Had upgraded springs and pushrods when the cam was done.
I suspect over reving or an oiling issue. Or, just a bad set of lifters. Who really knows? Chicken or the egg then for sure.
