New shortblock can't get the cam to slide in?
Old 02-25-2012, 11:57 AM
ABQ99TA's Avatar
Default New shortblock can't get the cam to slide in?
Started putting the motor together today and I can not get the cam even half way into the first bearing. Any advice?
Old 02-25-2012, 12:18 PM
davidws6's Avatar
Do you see any burrs on the cam bearings ? See any burrs on the bearings?
Old 02-25-2012, 12:48 PM
ABQ99TA's Avatar
Well now there is a small lip where I tried to push it in. No burrs anywhere
Old 02-25-2012, 01:09 PM
FastKat's Avatar
Did you lube the entire cam?
Old 02-25-2012, 01:14 PM
ABQ99TA's Avatar
Yes lots of lube. I just heard that the cam bearings are slightly different sizes from front to back. Can anyone confirm this?
Old 02-25-2012, 02:53 PM
chrisfrost's Avatar
Yes the outer diameters of the cam bearings are largest at the #1 and the #5 and #'s 2&4 being a little bit smaller OD and #3 is the smallest OD and all the inner diameters are the same .
Old 02-25-2012, 03:45 PM
butler's Avatar
Lick it and stick.
Old 02-25-2012, 05:02 PM
COPO9560's Avatar
You should mic each cam bearing and check against cam journals. If they are too tight you could force the cam in and end up burning up a bearing. Not a check everyone does on assembly but if yours is tight worth considering.
Bad news is you have to pull the crank to check past the first bearing with typical home tools.
Old 03-07-2012, 04:49 AM
ausls1's Avatar
Mine was tight to go in after new cam bearings with my new cam, I lubed the cam bearings with oil and the lobes with cam lube. But turned ok with no dramas, think I got some cam lube on the bearings as it went in but I put plenty of engine oil on the cam bearings do hopefully will be ok.
Old 03-07-2012, 04:54 AM
ThumpnZ28's Avatar
Check to see if the new cam bearings are cocked to the side in any way. That could explain your difficulty. The tool that is used to install/remove those bearings is very primitive and leaves a lot of room for human error.
Old 03-07-2012, 04:57 AM
ausls1's Avatar
Good idea, mine were installed by the machine shop that put the bottom end on mine together (didn't have the cam at the time). When I looked to see how much room there is to do them I'm glad I left it for them to do.
