LS1 block thread repair - with Time Sert kit
Old Mar 6, 2012 | 08:29 PM
S10xGN's Avatar
Originally Posted by Chevy406
The original bolt that I removed was only threaded ½ of the length of the bolt. The replacement GM bolt (shown in the first picture) was threaded all the way. I then purchased a Fel Pro bolt set from OReilly to replace the GM set that I had already torqued (i.e. when the threads failed). The Fel Pro set also was threaded all the way. I'm not sure when the bolt supplier changed the design, but it seems to be universal to be threaded all the way now. Note - this only applies to the two short M11 bolts, not the 8 long M11 bolts.
Interesting! I've always thought full-threaded bolts were not designed to to be used in critical torque situations. Then again, GM & Fel-Pro would know better than me...
Old Aug 27, 2012 | 11:51 AM
cwalker2006's Avatar
i had this just happen to me and the threads came out just like that, in about two different pieces.
Old Sep 6, 2014 | 09:57 AM
Iroc4u89's Avatar
Default I had an issue with the coolant filled bolt hole being cracked
I had an issue with the outer rear most head bolt being cracked from my donner car. So I did what any one would do. I welded the crack and used the serti-thread kit. It worked awsome!
Old Sep 6, 2014 | 12:54 PM
slowpoke96z28's Avatar
Originally Posted by 91sonomast
lol I'm just giving you a hard time man, I won't blame or poke fun at you at all for using the template, it's certainly the fool-proof way of doing it, we used the stop also, just moved it down the shaft farther.
You'se a bad mamajama to get after it without using the drill bushing.
As far as the flare at the end, that's what makes the time-sert so dope. Locks that son of a beyotch in place. I favor helicoils for low torque everyday fixes or open ended holes/soft metals, and time-serts for higher torque stuff.
Old Mar 20, 2015 | 08:43 PM
00SS4780's Avatar
Can you tell me where to buy this kit at???
Old Mar 21, 2015 | 08:12 AM
farmington's Avatar
there was one in the for sale posts a little while ago
Old Mar 21, 2015 | 10:57 AM
00SS4780's Avatar
Thanks I just found it.
