First look....new LSX lifters
#61
The preload debate regarding noise is really just a fight with sizing and grinding issues within the internals of the lifter bodies themselves. Some quiet up with more preload, some less. When the parts are ground straight (no taper) and sized properly, you don't have a single point controlling the valving of the lifter. That single point causes many problems once temperatures rise to operational levels. Many of those problems include noise, as well as not achieving full potential of the cam profile. When you have a straight lifter bore and piston as well the components being sized properly, preload becomes moot when regarding noise and is more about performance.
Having .002-.004" preload is not acceptable for "preload" IMHO. Think about thermal expansion here, especially in an all aluminum LS engine. Do you honestly think after engine temperatures increase, the .002" preload is going to remain? Answer is no, you'll have a few thou lash.
There is nothing to gain from running the piston down .100" on OEM parts, unless your trying to band-aid a noise problem. Valve float would have to be severe in most cases to cause contact from over pump-up, but it has happened before.
FWIW LS7 lifters have an average total travel of about .200", give or take GM's allowable tolerance window.
#63
The chart I posted shows the current LS7 lifter (GM p/n 17122490) to have a total plunger travel of 4.22 mm = 0.166". Not sure where the 0.200" came from. Did someone measure it?
#65
So in a lifter that is machined correctly, (the bore in the lifter body), preload should work anywhere from .010" to .100" with the lesser value preferred from a performance standpoint.
The lifters with issues would have to be tapered with the bottom in spec and the top out of spec. Interesting.
So the bleed down rate is plunger location specific. Hence folks trying all kinds of different preloads to shut them up.
#68
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
OP - That sounds terrible; much worse than the usual sewing machine sound. What was the length of the pushrods when you ran the LS6 cam and LS7 lifters? I ask because the LS6 cam has a smaller base circle than the stock LS1 cam which requires a different pushrod compared to stock.
#69
#72
I've decided....for sake of a fair comparison....to just pull the heads and replace the lifters. I'll be leaving everything else the same for now....cam, springs, etc. That way, there should be no debate as to what the root cause of the problem is. I'll install the new cam and springs in a month or so, but should get to changing the lifters in the next week or so.
#74
LS6 Camshaft - 204/218 .551/.541 117.5 LSA Please note that this cam has approximately a 0.050" smaller base circle than a stock LS1 camshaft. This smaller base circle will require longer pushrods for applications with stock length valves and no milling for the head surface.
^^^ That is from Thunder Racing's site and I agree after installing a couple LS6 cams that the base circle is 0.050" smaller. If all other components are stock then the correct pushrod length is 7.450" when running an LS6 cam.
salemetro: I think you are running a pushrod that is way too short. That noise is excessive and is obviously coming from more than a couple lifters. There is an issue with your preload, not the lifter choice.
thunderstruck507: The LS6 had the same pushrod length as every other gen 3 engine. The LS6 specific valves are longer to compensate for the smaller cam base circle. Also if you are running stock gaskets and a stock head milled .010" then you should be running the 7.4" pushrod.
It may be good practice to measure pushrod length but in alot of cases it causes more harm than good. I have seen quite a few folks that measure and end up with the wrong length for their engine.
#75
Also, do the LS7 lifters have the cup located 0.050" higher than the LS1 lifters...?
if so then using LS7 lifters with stock LS6 heads/cam and stock gaskets results in a net shortening of required pushrod length.
#76
#77
[QUOTE=5.3LJimmy;16053872]salemetro: I think you are running a pushrod that is way too short. QUOTE]
Something to consider, is that the heads have been milled, and I'm using aftermarket head gaskets (I didn't check compressed thickness)...also, there are 2 different height LS7 lifters that have been produced over the years...varying from each other by .050. I'm not sure which "batch" mine are from, but I would assume they are the taller ones. Additionally, I'm not sure if the comp trunion kit would change rocker installed height at all (can't imagine that it would). From looking at it, the swipe pattern looks normal. Also...it's an L33...so should have the same lenghth valves as the LS6...correct?
I get what you're saying, but I have verified the measurements 3 different times, as well as checking (for the hell of it) installed spring height. 7.295 has been the repeated zero-lash MULTIPLE times. Don't know what else to say here....except that I've been over it a few times, with the same result.
I'll be tearing into the car tonight after work, and finishing over the next few days as time allows. I'll be using OEM head gaskets this time, and won't be changing the cam out yet.
#79
i'm going to assume he had the cam on the base circle and not on one of the ramps. Beyond that, it's not rocket science.
#80
