New AFR 210 LSX heads
#41
![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
http://www.vcmstore.com.au/epages/sh...ts/VP-3HD-VT-Z
#42
Hi Matt,
Good to see your Fast Manifold /Throttle Body etc has arrived. Will be interesting to see the final outcome on the dyno. I have a SV8 ute with similar motor specs to yours. I see you want to put the Maloo down the 1/4mile at Ruapuna Park. I try to get to every meeting that they hold there and the last one we were at was fantastic. It was the Muscle car & Hot rod meet. Track wasn't the best but the 104 cars that turned up had a ball. Look forward to seeing you there. They are a great bunch of guys.
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
#44
Haven't had a chance to put it together and tune it yet mate , Mr Mamo is sending me over a mezeire electric water pump and an ATI underdrive dampner to go with the intake install so once they arrive it will be under way
#46
#48
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#49
Got my box of sweet new years treats turn up from Tony today, the man knows how to pack a box of gear and get it sent without a mark on it, big ups Tony your a fuckn legend !! ![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
anyhow couple pics of the rest of stuff waiting to go together for round 2
#50
So you better hurry up and get it all installed and tuned, because you know you're not going to get much sleep until you do! ![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
I look forward to seeing what the final results bring!
Keep us posted.
BTW, what size are the AFR210 chambers, 62cc..?
Keep us posted.
#51
![Secret](https://ls1tech.com/forums/images/smilies3/secret2.gif)
#53
#55
![Bomb](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_bomb.gif)
#58
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
#59
Hi Mate, not a fan of the clutch you've got, it's more of a tuned, standard engined cars clutch.
I am using a puk, solid centered plate with an increased pressure plate clamp pressure...apart from giving it some revs & a little shudder on take off I never have to worry about it never being up to task.
A twin plate you thought about would also have been the better option you should have chosen considering your mods.
#60
