Dual Springs Harder to Install than Single Springs?
Are dual springs harder to install than single springs? I've got a set coming, so I was just curious.
Thanks,
Josh
Thanks,
Josh
It depends on what type of tool use. If you use the spring compressor that screws down from the top by hand it is a little harder because you have to make sure the hooks(or feet) on the bottom of the compressor are long enough to catch the inside spring.
Regular spring compressors don't grab the inside spring that well and has atendency to pop loose. Everybody should do themselves a favor and either buy the Larry tool or make there own, it's about the best spring tool out there IMO..
Dan
Yes; they are much harder to install - particularly if you are attempting this while the heads are bolted on the short-block but only if the short-black and the heads are bolted to the frame under the hood. You will have a bitch of a time...
took me about 2 hours to do this with larry's tool........and when i did single springs with a normal spring compressor, it was damn near 6 hours, and this time i changed the seats and seals
jimmy
jimmy
Josh, yes, that will make it much easier. I just removed my 987's for the Cranes and I started out using the standard star handled compressor till I got pissed and just made a tool like Larry's, it was so much easier and you have much more room to work with and the keepers are a sinch to get in and out..
Dan
Dan
