Oil Filter O-Ring blowing out
What oil pump did you put in it? just a stock one, an aftermarket, did you change the bypass spring in the pump itself?
Oil pressure port above the filter. Could also be the filter itself is bad, did you reuse the original filter the second time?
Do you still have the stock pump?
You rebuilt the engine....all new bearings? Is it possible that the bearings are not aligned for proper oiling?
If you have an oil pressure gauge...how high does the pressure read, just by cranking? If there is a gauge, do you remember what this figure was before rebuilding?
Sorry for all of the questions, but they are part of the troubleshooting.
Assuming you have the right filter a gauge should give you some insights. I'd put one on before going through the effort of changing the pump.
