Spec me a cam for my 383 build.
Need help picking a cam for my 383, specs are below.
Hand ported ls6 heads
Mahle -6cc pistons...10.8:1 static cp ratio
Ls6 intake
3.73 gears
circle d 3c 3600 stall
occasional 150 shot of nitrous.
This is a street car with alot of track time (1/8th mile), I have a eps 226/234 .601/.598 113lsa cam right now but figured this is a little small. I would like to stick with my pac 1518 springs if possible, if not Ill have to get doubles.
Ls6 intake
3.73 gears
not sure if it helps, but i'm putting in a comp cam,
Cam specs: comp cams 54-460-11, 235/243 .621/.624 113 lsa.
Mines a 383, 11.1:1cr, Wiseco -8cc pistons, 241 hand ported heads, with a fast 102/102 intake, 3.73 gears, still working on putting the engine together, but helps give you an idea for similar build.
Still working on a converter size, but that gives me an idea on a converter.
I will be adding NOS as well, gives me an idea.
Geoff at EPS recommended a 230/238 .600/.600 112lsa, could have gone bigger but don't really want to buy double springs/lightweight valvetrain when I have brand new PAC 1518s. This is pretty close to what Comp recommended as well, theres was a 231/239 but the lift was .625/.625 which was pushing it.
238/242 .595/595 112lsa. I ran this trickflow cam in my stock 346 and it was on the big side, but when I put it in my 408 it was on the small side lol so it just might work great for you, make good power and be easy on your valvetrain
Pat G recommended this cam 243/247 huc lobes my car should be on the 500+rwhp i order the cam should be up and running in a month i had the ms4 cam and 799 heads on my 383 and dyno 440 so it should easily gain 60 with better heads (ported dart pro 1 225cc) and custom cam
These cars are money pits lol it foes help if you do one step at a time.....get all your machine work to get the block perfect, and build a bottom end strong enough to hold a lot more than you ever plan on throwing at it......then run your old heads/ intake and less than optimum cam.
Next, even if you have to wait a year or two, them get the great heads, intake and cam
