Compression Ratio Math Check Please!
Old Mar 26, 2012 | 07:44 PM
LS1 Racing's Avatar
Default Compression Ratio Math Check Please!
Just want to confirm my compression ratio for my LQ4 build:
Stock bore/stroke/piston LQ4
243 heads milled .017
Stock .051 thickness head gasket
I'm getting 11.1:1
Can anyone confirm my math?
Thanks in advance!
Old Mar 26, 2012 | 07:51 PM
batboy's Avatar
Valve relief on the pistons (like 4cc)? Do you know how far out of the hole the pistons are (deck clearance)? What size compression chambers on the heads? Is that about 60cc?
Old Mar 26, 2012 | 08:02 PM
LS1 Racing's Avatar
I believe the stock reliefs on an LQ4 are -2. Chambers are 61cc. This is an untouched bottom-end, so deck clearance is stock.
Old Mar 26, 2012 | 09:34 PM
batboy's Avatar
Using a typical deck clearance of 0.006" out of the hole, I get about 11:1.
Old Mar 26, 2012 | 09:41 PM
LS1 Racing's Avatar
Thank you!
Old Mar 26, 2012 | 10:18 PM
bww3588's Avatar
There is a lot more than 2 cc's worth of dish on an Lq4 piston. I just have valve reliefs in my flat tops and they are 3.2 cc's. I'd say it's 6 cc's or more.
Old Mar 27, 2012 | 08:33 AM
5.3LJimmy's Avatar
Stock LQ4 piston has a 7cc dish. Using that along with your info and -.006" deck height I get 10.6:1 CR.
Old Mar 27, 2012 | 10:48 AM
LS1 Racing's Avatar
THank you...
I rechecked and saw number anywhere from 6-7 cc dishes.
Thanks for catching my mistake!
Old Mar 27, 2012 | 11:16 AM
PREDATOR-Z's Avatar
I get around 10.6 SCR
Old Mar 27, 2012 | 12:15 PM
lemkerailroad's Avatar
dont mean to hijack but i have the same question
heres my specs:
pistons -6cc
799 heads milled .019
cc head @ 62cc
piston to deck -.013
.075 between piston and flat of head
3.905 bore
.050 thick gasket
any help would be great
thanks in advance
Old Mar 27, 2012 | 01:00 PM
Pumba's Avatar
Here is a good web site to bookmark that will calculate your compression ratio:
http://www.kb-silvolite.com/calc.php?action=comp
Old Mar 27, 2012 | 01:31 PM
dodson55's Avatar
my pistons had a 6 cc dish and my heads were milled .015 and the chambers measured 62 cc i didnt measure my piston out of hole but i guessed them at .005 out of the hole i figured my compression to be just a little over 10.5 i am going to say you have around 10.6
Old Mar 27, 2012 | 01:42 PM
thanks for the web site
saved it in fav's
Old Mar 27, 2012 | 01:54 PM
LS1 Racing's Avatar
Thank you! I'll bookmark that for the next build!
