Oil pump
Old Mar 29, 2012 | 08:43 AM
danrun's Avatar
Default Oil pump
What should I go with? Fresh complete build. Tps 228r cam, ls7 lifters, and mostly stock inside other than that. I put a gm replacement and when it got to full operating temp the psi was around 23. I dont like that. What should I go with?
Old Mar 29, 2012 | 09:15 AM
MT0911's Avatar
A Ported LS6 Pump would do great or you can look into Melling Oil Pumps. I personally run the Ported LS6 and I'm usually around 50 psi cruising, and I have had zero issues so far.
Old Mar 29, 2012 | 09:58 AM
danrun's Avatar
If I went with a melling ou think go with a high pressure? And can you order the ls6 already ported somewhere?
Old Mar 29, 2012 | 11:12 PM
chrisfrost's Avatar
Most likely You have some bearing clearances that are a little larger than optimum , but FYI Amazon has the Melling 295 for $60 brand new ,,,,,,it's from Northern through Amazon ,,,,,good luck
Old Mar 30, 2012 | 08:16 AM
danrun's Avatar
Yea after my oil pump went out I've gd nothing but hell. The day after I replaced the pump a lifter collapsed and scarred my cam. Fixed all that and 2 days later broke 2 rods and cracked one. So I decided to just do a complete rebuild since I already had alot in it. The oil pump may be good. I just had low oil pressure the day before the rods broke
Old Mar 30, 2012 | 08:33 AM
danrun's Avatar
So don't go with a high volume?
Old Mar 30, 2012 | 08:49 AM
mark21742's Avatar
I'd go ahead and run the high volume pump. 10296 I think? That's what I run in my motor 50-55psi warm idle, 75-80psi in the higher rpms.
Old Mar 30, 2012 | 09:55 AM
danrun's Avatar
Stock bottom end?
Old Mar 30, 2012 | 10:18 AM
mark21742's Avatar
I see no problems with running the high pressure pump on a stock bottom end....I'm running a forged stroker though
Old Mar 30, 2012 | 10:19 AM
RedRocketZ28's Avatar
I ran the melling 10296 HV pump in my 00 SS. Worked great for me in my cam only/spray setup. I am using the same pump in my current build as well.
