Help dynamic compression ratio lq4
Old Mar 29, 2012 | 11:16 AM
KLRS10's Avatar
Default Help dynamic compression ratio lq4
I called texas speed and was recommended a torquer v2 cam. Well when i crunch the numers for compression I get 11.2:1 static compresion and 9.1:1 dynamic compression. From what I read you want to stay below 8.5:1 dynamic compression for 93 orctane.
Did I calculate it right and is the dynamic compression to high for 93 octane?
Cylinder head colume: 64.5 for 243 heads
Piston Head volume: -2cc for diamond racing 11512 dish
Gasket thickness: 0.051 for standard 6.0 head gasket
Gasket bore: 4.030
Cylinder Bore: 4.030 for engine bored .30 over
Deck Clearence: 0.006 below the deck
Stroke: 3.622
Rod Length: 6.125
Intake closing point: 61 deg for torqer v2 cam is 46 and plus 15
http://www.kb-silvolite.com/calc.php?action=comp
http://www.diamondracing.net/pdf/Chevy-Section.pdf
Old Mar 29, 2012 | 11:43 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Not sure where your numbers are being messed up...I'm getting about 10.6-10.7:1 static, and then 8.1:1 dynamic with the Torquerv2 (I assumed 112 LSA and our standard 110 ICL because that gives the 46ºABDC IVC event you listed @.050").
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Mar 29, 2012 | 11:47 AM
96lt4c4's Avatar
I am getting about 8.0 DCR
edit...sorry 2 should have been positive...
Good to go now here is what I got.
Old Mar 29, 2012 | 11:53 AM
^^You've got the right intake closing angle and all, but your numbers are off too...either you've got the pistons OUT of the hole instead of IN the hole, or something.
__________________
Old Mar 29, 2012 | 12:14 PM
KLRS10's Avatar
thanks a lot. i see a neg dish actually is positive and not negitive. that is the difference.
Old Mar 29, 2012 | 01:34 PM
96lt4c4's Avatar
/\ /\ Sorry fixed it
