Shelf vs custom cam specs?
Old Apr 2, 2012 | 01:56 PM
  #41
gregrob's Avatar
I'm so sad! A bunch of clueless internet experts don't agree with me. Oh noes, what will I ever do!?
Old Apr 2, 2012 | 02:00 PM
  #42
moeZ28's Avatar
Kill yourself...please!
Old Apr 2, 2012 | 08:17 PM
  #43
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Times like this, I actually DO wish 01Red could swing that ban-hammer.... With a QUICKNESS!!
Old Apr 2, 2012 | 10:45 PM
  #44
studderin's Avatar
This custom mad more power then a Trex, its smaller and runs better too
https://ls1tech.com/forums/dynamomet...nly-setup.html
Old Apr 2, 2012 | 10:51 PM
  #45
TXZ28LS1's Avatar
Originally Posted by 01ssreda4
Shelf cams are also designed by cam designers not pre-schoolers. There was a thread here a while back where people were asked for their custom cam specs. LOTS of people with cams from the same vendors had identical specs. Coincidence? Doubtful. I attribute it to a "shelf" cam designed by that vendor that has proven itself, and he suggests it to his customer. Cams have been around for 100 years or more, nobody is re-inventing the wheel. With all these vendors here at my disposal I chose a shelf cam, a proven one, and have been happy so far with the results. I do not need that warm and fuzzy false feeling when I lay down at night thinking nobody else in the world has my one of a kind, ground breaking, never been done, custom grind
This!!
I think im gonna get a 218/365 1000/1000 on a 180 lsa cam spec for me and see how it goes.. lol
OP, why not just go with the vindicator cam? Since your car isnt a DD and you have already driven a TREX.
Old Apr 2, 2012 | 11:35 PM
  #46
09camaro383's Avatar
Don't get but hurt but this will be your 5th cam and you still don't know what to get!!!
Old Apr 3, 2012 | 04:51 AM
  #47
moeZ28's Avatar
Well I was mainly looking for info on the two cams in the original post as stated several times already...since I have not had experience with either of them. But for some reason all you ******* morons want to do is bad mouth what you think is my choice in cams. I didn't ask for a recommendation...only information on the cams in question.
Old Apr 3, 2012 | 06:46 AM
  #48
moeZ28's Avatar
Vindicator is still too big in my opinion for stock cubes. If you guys paid attention to what's been posted, I stated already that I had a trex and it was too big for stock cubes. IMO anything larger than a RAPTR or G5X3 is too big for stock cubes unless you want a track only cam.
Old Apr 3, 2012 | 07:20 AM
  #49
*02WS6TURK*'s Avatar
Custom grind all day.
Greg & Moe
Attached Thumbnails Shelf vs custom cam specs?-317288_10150289675827338_572657337_7857157_526448202_n.jpg
Old Apr 3, 2012 | 10:18 AM
  #50
I was on the same boat wanted thunder racing stroker cam I think specs are 247/251 but I had Pat spec me a cam and gave me a 243/247 decided to go with what the expert recommended shelf cams are max effort cams for a wide range of different setups so you can go smaller but it will perform better
Old Apr 3, 2012 | 05:51 PM
  #51
studderin's Avatar
what about a Trex cam, I think that would be great for you.
Old Apr 3, 2012 | 09:29 PM
  #52
garygnu's Avatar
some cams like the EPS cams have more intense lobes then others for a faster lifting rate.
Old Apr 3, 2012 | 09:40 PM
  #53
squirlNUTZ's Avatar
I would go with the custom grind. The shelf grind and custom are similar in numbers, but with the information you provided to Futral, you got back a "custom" grind that the expert : I don't think any one would argue that: says will function better for you and your car.
They appear to be similar but there must be a reason Allen recomended the slightly smaller camshaft for you. I would think the custom ground cam would out perform the shelf grind or he wouldn't have recomended it.
I still have not ordered my custom grind from Futral, and I will some day, but it's close to an advertised cam they have sold for awhile. I also emailed them about one of the shelf cams but they recomended a custom ground cam to fit my application so that's what I'll get.
I don't know if any one could tell you the difference in performance between the two except Allen Futral
Old Jul 16, 2012 | 10:32 PM
  #54
ba96ta's Avatar
You probably have a cam by now, but have you seen the tsunami cam from tsp. Could be wrong, but that looks like a good choice.
Old Jul 16, 2012 | 11:23 PM
  #55
moeZ28's Avatar
Picked up a G5X3 112 for $265 shipped...
