Pro's/Con's - 4.8 vs. 6.0 heads
I have both in the garage waiting to be used. The plan of course was/is to port-polish, the one I eventually choose. And sell the other.
I know about the compression increase with the 4.8 (similar to 5.3) and the flow of the 6.0. Are there any other similarities/differences?
I will be using an '02 LS6 cam w/'01 LS6 springs. Would I need anything else, between the two heads? Pushrods? Rockers?
The biggest difference I can contribute is the weight. The 4.8, of course are aluminum, the 6.0's are iron.
** Any advice and help is appreciated. Just trying to get the most for less out of my stocker 346!
Both are bad choices. I'd scrap them both. Too much work to get the 4.8L to a reasonably usable state and you'll pay too much to get the 6.0L iron heads ported.
You can get a set of 5.7L heads for next to nothing and do whatever porting you want.
Big disagree here. The 4.8 and 5.3 heads are exactly the same. They even have the same casting numbers. Therefore why would they be a negative?
I do agree with the iron 6.0 heads, and didn't even know they made these heads. What is the casting number on the heads?
The 4.8/5.3's should work best. The 317 6.0 heads do flow better and are lower compression. If you had a set of these they would work nicely and be great if you even decited to bolt on a charger or Turbo b/c of the lower C/R.
Well, JZ, if I found the right number on the 6.0's, the casting number is 873. Plenty of other numbers etched into the head.
I got these heads not fully aware of the aluminum version available. I just saw 6.0 and grab them. Oh well, know of anyone wanting 6.0 Iron?
I didn't post this thread for opinion, I just wanted to know pure raw information on what I had, and what it's being combined with. Thanks for the back up on the 4.8s, JZ.
