Heads in the shop. To Mill or not to Mill?
I need to let him know tomorrow how much to mill.
I am going with the Comp Cams Thumpr cam. Specs are:
Cam Style Hydraulic roller tappet
Basic Operating RPM Range 2,000-6,400
Intake Duration at 050 inch Lift 219
Exhaust Duration at 050 inch Lift 233
Duration at 050 inch Lift 219 int./233 exh.
Advertised Intake Duration 275
Advertised Exhaust Duration 295
Advertised Duration 275 int./290 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.553 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.536 in.
Valve Lift with Factory Rocker Arm Ratio 0.553 int./0.536 exh.
Lobe Separation (degrees) 109
I need to know what you guys recommend for how much to mill and what do I do for push rod length and do I need to worry about accessory alignment?
Engine Mods:
LM7, factory short block
Milled heads? 862 heads With LS6 Springs
Thumpr Cam
2" Primary LT headers, 3" exhaust with duel SLP Loudmouth mufflers
Edelbrock Performer RPM duel plane intake
Holley 750 cfm carb probably will do E85 conversion
MSD 6LS
Thats what it will sound like, beautiful!
I am a Firefighter/Paramedic and I stopped by a local shop while I was on duty so the guy was very nice and said he would take care of me.
How much would you remove ?? Stockish daily driver with a tune.
