Intake manifold removal question
Old 04-09-2012, 04:11 PM
ViperT4's Avatar
Default Intake manifold removal question
So I'm getting everything together for a cam install this weekend. I'm also replacing lifters so I'm not worrying about them every time I get on the go pedal- which means the heads are coming off, which means the intake manifold is coming off. I've heard that a lot of people have problems breaking the oil pressure sensor when they remove their intake mani's, what are you guys doing to break them? Seems like if you're careful unbolting everything and then slowly lifting up it should come off fine, but I've never done it before so what do I know.
Anyway, can someone tell me what to look for so as to not break mine?
BTW car is a GTO, so I have a lot more room in the back of the engine bay compared to F-bodies, is that just your guys' issue?
Old 04-09-2012, 04:12 PM
Mean87SS's Avatar
Its the booster hose that breaks it.
They wrap around it and sometimes are very brittle.
Old 04-09-2012, 04:32 PM
BIG_MIKE2005's Avatar
Yep.
sure fire way to not break it is to disconnect all the vac lines on the back of the intake before you pull it out. Also you can use rubber bands to hold the bolts up on the rear cause you wont get those out with it in the car.
Its alot easier than some people make it sound. Just take your time & dont yank on anything, if it doesnt wanna come out look it over again to make sure everything is done to remove it properly & then just lift & slide toward the front end.
Old 04-09-2012, 05:12 PM
batboy's Avatar
The intake manifold is fairly easy to remove on the GTO compared to the F-body guys that have the rear part tucked under the cowl.
Old 04-09-2012, 06:57 PM
christiandoy's Avatar
what big mike said!
Old 04-09-2012, 07:05 PM
ViperT4's Avatar
Sounds good, thanks for the tips everyone.
Old 04-09-2012, 08:02 PM
I know I didn't contribute at all but no problem Viper !
Quick Reply: Intake manifold removal question
