231/237 too big???
Old Mar 26, 2004 | 11:23 PM
  #41
CAT3's Avatar
Restricted User
DenzSS-milling issue, thats why I am still at stock heads, have a set milled .022, thats about .012 too much.
John(gator) Nice. Not everyone is so lucky as you.
Old Mar 26, 2004 | 11:26 PM
  #42
RJF's Avatar
RJF
im waiting to get my cam they keep saying any day now.But im going to be running it with new pushrods,dual springs ls6 oil pump double roller timing chain,retainers,4400stall,125 shot,in tank fuel pump,home ported heads,Long tube headers,T-arm,lcas air bags relocation braks.I think you would like it I hope i do if I dont ill sell ya mine
Old Mar 26, 2004 | 11:31 PM
  #43
93octane's Avatar
Originally Posted by gator's 99TA
small cams make cars go faster. that is why my pig runs mid 11s on stock heads
I don't see anything wrong with mid 11 1/4 times cam only.
Old Mar 26, 2004 | 11:33 PM
  #44
93octane's Avatar
Originally Posted by CAT3
Do the Heads and You will be in love with the car all over again.
Easier said than done. I need green.
I am about to price out what the difference would be between going with h/c, and then just cam and necessary valvetrain equipment.
Old Mar 26, 2004 | 11:39 PM
  #45
CAT3's Avatar
Restricted User
Same reason I havent done the heads, have a set but milled to much!
  #46
93octane's Avatar
$2,239 - Patriot Performance Stage II LS6/LQ9 Cylinder Heads with 59cc Combustion Chamber, TSP 231/237 or TSP 231/231 Camshaft, Hardened Pushrods, Heads & Cam GM Bolt & Gasket Kit.
$720 - Texas Speed 231/237 Camshaft, Crane Double Valve Springs, Titanium Retainers, Hardened Spring Seats, GM Valve Seals, Texas Speed & Performance Hardened Pushrods.
$1519 difference in price.
How many horses could I gain from a set of heads with this cam? I still need the LS6 intake as well.
Old Mar 26, 2004 | 11:41 PM
  #47
93octane's Avatar
I live in TX as well, so I have to pay tax on it!
Old Mar 26, 2004 | 11:49 PM
  #48
CAT3's Avatar
Restricted User
But shipping should relieve you of tax.
I am telling you, if you can get the heads. Not sure about power difference numerically, but pull wise, I am sure it will be worth it. Or do like me and others, do the cam, fall in love with the pull factor, then get the $$$ for the heads and fall in love all over again.
Old Mar 27, 2004 | 12:03 AM
  #49
93octane's Avatar
Well, this cam does like the spray. Maybe the 231/237 and a 100 shot on stock heads. What sucks is I want to do everything at once so that I only have to pay for tuning once. If I go with heads later on, I still have to pay for tuning a second time since I don't own LS1 edit.
Old Mar 27, 2004 | 12:18 AM
  #50
CAT3's Avatar
Restricted User
talk to the tuner, some offer xx months of upgrade retunes, or they may. Tuning for adding heads aint bad at all. more or less a little WOT adjustment, maybe timing, but the cam will take more time to tune, so they may work with you. Ask Trevor or Jason @ TSP, they might have some deal for you as well. If TSP is not tuning it, make sure they know about adjusting the min & max MAP values, add 10 to each or you might get repeated p0130 or something, made the trans act up and SES lightup.
Old Mar 27, 2004 | 12:20 AM
  #51
DenzSS's Avatar
Of course it does. That's the only reason I can think of on a LS1/LS6 to crutch the exhaust that far. That is a lot of duration on the exhaust side.
Old Mar 27, 2004 | 07:33 AM
  #52
jimmy 2 Times's Avatar
i have the 231/237 on stock heads, it sounds nasty as hell, it has great power, and it will turn some heads
as far as the LM and ORY, i think it is too loud, thats why i will be muffling mine soon, no track numbers yet, but im around 400 at the wheels with a tune from mikey at rapid
i say get
Old Mar 27, 2004 | 08:02 AM
  #53
z98's Avatar
z98
Oh by the way I still have a totally stock bottom end. The 231/237 is about the largest you'd want to do without piston work.
hmm why?
Old Mar 27, 2004 | 08:47 AM
  #54
CAT3's Avatar
Restricted User
z98, because at the lift vs duration you are getting close to the pistons. So far the most milling I have heard of is .006" of a set of heads w/ 231/237 cam. I myself have a set of .022" milled and wont put them on cause I know there will be contact. Open up the bottom, fly cut the pistons and you have much more to play with.
Old Mar 27, 2004 | 10:59 AM
  #55
Mike98WS6's Avatar
You guys are killing me here. I have to sit and stare and my 231/237 cam in the box while I wait to put it in. I'm dying to feel the power!!
Old Mar 27, 2004 | 11:35 AM
  #56
AdamSS's Avatar
I wonder if having that cam (TSP231/237) with FLP LT Headers (with cats) would pass the emmisions (meaning that OBDII test) if the car is properly tuned, and all the error codes are erased ?
Old Mar 27, 2004 | 12:45 PM
  #57
beachin99's Avatar
navy david ss-it was a 2001 blaster w/pipe silencer and tires and i got $2000 dollars out of it! so my prob. is that i cant afford the heads at the time plus get everything installed. other wise i would get the H/C package
Old Mar 27, 2004 | 12:48 PM
  #58
beachin99's Avatar
thanks to everyone else that posted! it was all great feed back i appreciate all the great comments! looks like thats the cam im getting! i cant wait for this!!!
Old Mar 27, 2004 | 01:45 PM
  #59
93octane's Avatar
I think you made a good choice. Let us know how the install goes.
Old May 28, 2004 | 01:12 PM
  #60
badazzhawk's Avatar
Default its fine.i love mine
i had my 231/237 cam in for about a month and love it. It makes great power. if you throw in some 3.73 at least and a stall if you got a a4..and some good tunning...that cam kicks ***...it pulls like a ****...i had a tr244...it was nice and yea it had more torqe in the low end....but i was spinning to damn much....with this 231/237 its nice...i use my car as a daily driver...i drive about 20 miles back and forth each way to work..so about 40miles a day to work and also 15 miles to school there and back....5 days a week.had no probs so far and runs great...i kill everyone so far...they may think they got me on the take off...but i love it when i hit about 4000 rpms...its like hitting a button..
