TRex w/ Decked 243 heads
your gona have to flycutt. The amount is up to you, the norm is .100, but alot of good race setup run fine with a LOT less. lol
If you measure it and map it out your see whats chasing, and whats getting chased. And thinking about what that means and what the MIN pTv numbers guy talk about your notice it makes sense of what the engine can have problems with these numbers.
Stock LS1 pistons I've cut .100 and been fine. I've heard guy going .120 on SBE with 200hp and no problens cutting. That spot on the crown doesn't have to be that thick, your melt it down or butt the ring and pop the land off. Before any piston damage form cutting alot
