Help
Old Apr 29, 2012 | 01:38 AM
camarovon's Avatar
Default Help
I installed a torquer v2 cam and now I got valvetrain noise what could it be
Old Apr 29, 2012 | 02:21 AM
justin455's Avatar
Douchebag On The Tree
https://ls1tech.com/forums/generatio...rnal-engine-5/
Old Apr 29, 2012 | 02:24 PM
crainholio's Avatar
What pushrod length did you use, did you torque the rockers in GM sequence or just run 'em down, how much lifter preload did you get from your measurement, etc etc etc...
Old Apr 29, 2012 | 06:46 PM
camarovon's Avatar
I know that I got the correct push rod length,but could u please explain the correct way to adjust rockers
Old Apr 29, 2012 | 06:49 PM
camarovon's Avatar
I got 799 ported heads,they are not milled so texas speed told me to get a7.4 pushrod
Old Apr 29, 2012 | 06:52 PM
crainholio's Avatar
It's worth clarifying that I didn't say adjust, I said torque. The GM procedure has you tightening each rocker when the lifter is on the cam's base circle, not on a lobe...this prevents excessive loading of the lifter and potentially damaging the piston and/or spring.
What was your zero-lash pushrod length measurement?
Old Apr 29, 2012 | 06:58 PM
camarovon's Avatar
I never checked with a checker
Old Apr 29, 2012 | 06:59 PM
camarovon's Avatar
I just used what they told me
