Serious coolant leak on Drivers side
Just buttoned up a head /cam install (not my first) and I'm getting a steady coolant leak toward the header collector and oil filter. I can't really see where it's coming from. Any suggestion would be greatly appreciated.
Originally Posted by ss rally red
Sounds like you left out one on the plugs that need to be transfered from the removed heads.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Originally Posted by pdd
yup. i did the same thing. had coolant all over the place ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Hypothetical questions: Say I had some serious gashes( a 1" by 2" area) on the block between cyliders 3 and 5 just above the bores, could this be the issue?
Originally Posted by max's dad
I can see that for the passanger side. The driver side has the temp sensor. Both are in place.
I had a similar problem It happened after a few hard passes. The dowl pins should be replaced everytime the heads are taken off. If not they have a chance of getting crooked and not letting the head set all the way down on the block. This happened to me so I learned the hard way
Leaking was not immediate. Drove the car for about 40 miles and it seemed fine. Came home after dinner to find coolant trail under the car.
Just for grins, you could check and see... The coolant plug is (or should be) toward the top of the cylinder head, almost directly above the back spark plug on the passenger side.
There are extra bolt holes cast into LS1 heads, and sometimes they are tapped/drilled in too far and will cause a coolant leak. They are right near the header flange on both heads.
I once got a set of heads from a sponsor and coolant was pouring out one of these extra holes. Strange stuff, but its at least something to check
Heads are 5.3s. This was my first time using Felpro gaskets and ARP bolts. Everything was torqued to spec. Is 75ft lbs enough? It seems as if it took more muscle with the t-t-y oem bolts.
Yeah sounds like the Infamous " U notch" strikes again...
Had the same exact problem, my car is an 01' and didnt have notched heads to begin with, but i put the Patriot 5.3's on and they are 99-00 style castings that have the notch and didnt even think about it and i looked at the deck a 1,000 times before i installed them, but its a simple honest mistake but i tried using the MLS GM head gaskets and it pissed coolant from the notch on both sides. Replaced them with the graphites, problem solved!
