Anyone have info on clearnacing for Big CI buildups?
Old 03-27-2004, 07:48 PM
Restricted User
CAT3's Avatar
Default Anyone have info on clearnacing for Big CI buildups?
Thinking about putting my own Big Incher together. Not sure whether to go 387all bore, 396, 408 or larger. Looking at using a Darton Sleeved block, either stock or Stroker Crank, Callies. What combos dont require clearancing? I would guess the stock stroke or up to the 4.000" wouldnt require it, but not sure. Any info on this is greatly appreciated.
Charlie.
Old 03-27-2004, 08:45 PM
stealth's Avatar
You're asking enigne builders to disclose their secrets.
Old 03-27-2004, 08:56 PM
Restricted User
CAT3's Avatar
Not the trades secrets, just an insight on whether a certain combo doesnt require any. I see your point, but dont think it applies that much. Looks like its going to be cheaper to pick up a short block from a sponsor, than to build one anyway.
Old 03-27-2004, 09:00 PM
GTBMad's Avatar
The only clearancing issue we had with the callies 4.000 crank was the piston to reluctor wheel using diamond 4.130 pistons.
Old 03-27-2004, 10:52 PM
99 Black Bird T/A's Avatar
Received 1,454 Likes on 1,008 Posts
On the clearance issue for strokers, a lot will depend on what combo of parts are selected. Sometimes with a 4 inch crank you can need to clearance depending the rods & bolts used etc. The answer can change depending on what parts are selected.
Old 03-28-2004, 12:45 AM
LS1TECH Sponsor
Steve - Race Eng's Avatar
Default clearance
Charlie.
Charlie,
The bore size has much to do with whether or not the rod bolts will clear. I can tell you that the Lunati rods (6.125") will clear the bottom of the cylinders and Darton sleeves at 4.125" bore and 4" stroke. I'm assembling a short block on a block I sleeved with Darton MID's. The only problem is the reluctor hit the machined piston for cylinder 8 and I had to further machine it. I made Lunati aware of this so I expect they will make the necessary changes to their pistons.
The Eagle rods at 4" stroke will require clearance notches at the bottom of the cylinders regardless of bore size.
Steve Demirjian
Race Engine Development
Old 03-28-2004, 02:10 AM
strokedls1's Avatar
Yah, we had to notch the bottom of the cylinders to clear the rod bolts with a callies 4" and eagle 6.125" h beams on an alluminum block.
Old 03-28-2004, 08:49 AM
Restricted User
CAT3's Avatar
Thank you guys, very much appreciated.
Charlie
